Degraded Drive - No Errors
sartis-glenn
Hello Everyone,
My Pool consisting of a 8tb drive is degraded, the UI is giving me this error code:
"Pool Archive_Old state is DEGRADED: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
The following devices are not healthy:
  • Disk ST8000VN004-2M2101 WKD3NPJM is DEGRADED"
On Friday, when this error first showed up, I had 18 write errors, now after running a smart test, the disk doesn't show any errors, is however still degraded.
What is my best course of action here?
I'm very new to true NAS and incredible inexperienced.
Do I just replace the drive? It is well within warranty, or is it fine?
Some screenshots are attached, if they are of any help.
Thanks for your help ahead of time!
We don't yet see sufficient information to decide if the disk is really bad (although it doesn't look hopeful at this point).
run smartctl -a /dev/sda (and see if the extended offline/long test is complete)... re-run it after a few hours if not (or watch the status in the disk SMART details in the GUI).
sartis-glenn
Thanks for the advice, I am currently running a long test, so when it is done, I will return with the results
sartis-glenn
The test is not yet complete, these are however the current logs,
Model Family: Seagate IronWolf
Device Model: ST8000VN004-2M2101
Serial Number: WKD3NPJM
LU WWN Device Id: 5 000c50 0e063e219
Firmware Version: SC60
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Apr 11 22:40:45 2022 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Self-test execution status: ( 249) Self-test routine in progress...
90% of test remaining.
data collection: ( 559) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 708) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 083 064 044 Pre-fail Always - 213245261
3 Spin_Up_Time 0x0003 082 082 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 385
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 074 060 045 Pre-fail Always - 23539553
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 729
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 7
18 Head_Health 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 052 052 040 Old_age Always - 48 (Min/Max 23/48)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 1642
194 Temperature_Celsius 0x0022 048 048 000 Old_age Always - 48 (0 23 0 0 0)
195 Hardware_ECC_Recovered 0x001a 083 064 000 Old_age Always - 213245261
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 1
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 221h+35m+10.896s
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 33241879920
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 21428549501
SMART Error Log Version: 1
No Errors Logged
# 1 Extended offline Self-test routine in progress 90% 729 -
# 2 Extended offline Aborted by host 90% 728 -
# 3 Extended offline Interrupted (host reset) 80% 726 -
# 4 Short offline Completed without error 00% 724 -
# 5 Short offline Completed without error 00% 653 -
# 6 Short offline Completed without error 00% 494 -
# 7 Short offline Completed without error 00% 53 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
NugentS
Hope you are happy losing that data as you have no resiliancy in that pool. (Mind you the name seems to imply it may not be critical data)
Please use code tabs when inserting data like that - its easier to read
Lastly, please read the forum rules - the ones about posting your hardware setup - its an important part of us being able to help you.
Wait till the smart test fails or suceeds and then post the results please
sartis-glenn
Thanks for your response,
The data on the drive is unimportant, as I am in the process of migrating to the server, so the data is stored on a separate storage system I am upgrading from.
Thank you for the advice on the forum rules, I am running
  • MSI B660M-A Pro Motherboard
  • Intel(R) Core(TM) i3-10100 CPU @ 3.60GHz 4 cores (8 threads)
  • 8gb DDR4 RAM
  • 2 HDDs, 1 NVMe SSD all in raid z (data redundancy added later on)
No hard disk controllers or network interfaces besides the ones included on the MOBO
At least one CRC error points to a cabling problem at some point...
It's absolutely not clear what this means... RAIDZ1 needs at least 3 drives. Did you mean a 2 or 3 drive Mirror? (equivalent, or sort of, to RAID1)
zpool status -v should remove any lack of clarity for us.
sartis-glenn
Sorry I misspoke, it's a raid0 array (stripe) as I'm migrating data from one server to my new one, I don't have the spare HDD's in my pool yet.
    NAME                                    STATE     READ WRITE CKSUM
    Archive_Old                             DEGRADED     0     0     0
      a04423d1-540e-4ec9-a0f0-f0d2c7743a1a  DEGRADED     0     0     0  too many errors
the zpool status reads:
here is my script output:
  • zpool.txt
NugentS
You realise (you must) that you have absolutely no resiliancy in any of your pools?
No chksum errors, but Archive_Old - and its single disk is suspect.
The drive is a bit warm
Have you run zpool clear? (to be clear - please don't)
As @NugentS said, you're playing with fire.
Three different pools, and each pool is comprised of a single drive.
There is no mirror nor RAID-Z involved in your ZFS pools. There is no redundancy whatsoever. (According to your .txt output of "zpool -v")
sartis-glenn
Like I said already, Im in the process of moving data to the drives, meaning it is stored offsite. No, I haven't done zpool clear and I most likely won't as I have made use of my warranty and have started the replacment process.
Thank you all for your help!
