I built freenas with esxi and directly connected the hard disk to freenas through the RMD mode of esxi. After one of the hard disks is damaged and replaced with a new hard disk, all the hard disks are displayed as graded, including the newly purchased hard disk. I'm sure these three hard disks are intact! How to cancel the graded display of status? thank you!
root@nas[~]# zpool status -v
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:07 with 0 errors on Sat Apr 23 03:45:07 2022
NAME STATE READ WRITE CKSUM
boot-pool ONLINE 0 0 0
ada0p2 ONLINE 0 0 0
errors: No known data errors
pool: raid5
state: DEGRADED
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
scan: scrub repaired 0B in 11:59:01 with 82 errors on Tue Apr 26 01:11:48 2022
raid5 DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
gptid/82bbcf7f-c09b-11ec-abfa-000c29a65d01 DEGRADED 0 0 1 too many errors
gptid/76b96c6d-684c-11ea-bc57-d05099d28fdf DEGRADED 0 0 1 too many errors
gptid/6b0d28cd-6413-11ea-9ee9-a0369f581100 DEGRADED 0 0 1 too many errors
/var/db/system/rrd-1d75fdc729874c0cb54b5da2552ea8c9/localhost/df-mnt-raid5-ss/df_complex-used.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/zfs_arc/cache_ratio-L2.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/zfs_arc/cache_ratio-arc.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/zfs_arc_v2/arcstat_ratio_arc-misses.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/zfs_arc_v2/arcstat_ratio_data-demand_data_hits.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/zfs_arc_v2/arcstat_ratio_data-demand_data_misses.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/zfs_arc_v2/arcstat_ratio_data-prefetch_data_hits.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/zfs_arc_v2/arcstat_ratio_metadata-demand_metadata_hits.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/zfs_arc_v2/arcstat_ratio_metadata-demand_metadata_misses.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/zfs_arc_v2/arcstat_ratio_metadata-prefetch_metadata_hits.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/zfs_arc_v2/arcstat_ratio_metadata-prefetch_metadata_misses.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/zfs_arc_v2/arcstat_ratio_mu-mfu_hits.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/zfs_arc_v2/arcstat_ratio_mu-mru_ghost_hits.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-0/cpu-idle.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-0/cpu-interrupt.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-0/cpu-nice.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-0/cpu-system.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-0/cpu-user.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-1/cpu-interrupt.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-1/cpu-nice.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-1/cpu-system.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-1/cpu-user.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-2/cpu-idle.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-2/cpu-interrupt.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-2/cpu-nice.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-2/cpu-system.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-3/cpu-idle.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-3/cpu-interrupt.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-3/cpu-nice.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-3/cpu-system.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-3/cpu-user.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-4/cpu-idle.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-4/cpu-nice.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-4/cpu-system.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-4/cpu-user.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-5/cpu-interrupt.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/cpu-5/cpu-system.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/interface-vnet0.1/if_octets.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/interface-vnet0.1/if_packets.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/interface-vnet0.1/if_errors.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/interface-bridge0/if_octets.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/interface-bridge0/if_errors.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/interface-bridge0/if_packets.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/df-mnt-raid5-cs/df_complex-free.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/processes/ps_state-sleeping.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/processes/ps_state-stopped.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/df-mnt-raid5-ss/df_complex-used.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/processes/ps_state-wait.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/processes/ps_state-zombies.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/rrdcached/gauge-tree_depth.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/rrdcached/gauge-tree_nodes.rrd
raid5/.system/rrd-1d75fdc729874c0cb54b5da2552ea8c9@auto-2021-10-29_19-00:/localhost/rrdcached/operations-receive-flush.rrd
pool: boot-pool
state: ONLINE
ada0p2 ONLINE 0 0 0
pool: raid5
state: DEGRADED
