ThisTruenasUser
- Apr 19, 2023
Hi all
Firstly the primary reason to use truenas is multiple ISCSI for games, with deduplication.
Truenas is running as a virtual machine in proxmox.
It is a raidz1 5 x 4TB pool.
2 x 16GB intel optane as dedupliction. They were cheap.
There are 2 12TB sparse drives
To get the dedup data down to a managable level, they zvols are 1MB block sizes.
They are shared through ISCSI and ormatted with 1MB block sizes, which is not an issue for a big steam library.
By changing the block size, the dedup dataand I assume the I/O on the optane drives redude down by 64x, so nearly 2 orders of magnitude. The dedup data definitely did.
So if using dedup for some intensive with small block sizes, will be demanding I guess, but in my case it seems.
So now are looking at swapping out the optane drives for 2 x 256GB standard NVMe drives I have already.
The are adata SX8200 256GB. What is important is they have a small ram cache.
So other data do now use deduplicaton, maybe 400GB files in standard samba share of various file sizes. it is mainly static data.
When initially recopying over, could be slow as the NVME drives would be hit hard. That is about the only time it would be.
Sometimes I sync data to it, around one a week.
I am NOT spending cash on expensive high optane dirves for dedup. It is not worth it & would be better off buying more actual storage.
If buying more storage, have no need to truenas, as file sharing can just be setup on proxmox.
I have read the guide on special dedup devices here already.
www.truenas.com
So in this context, are 2 standard nvme drives as described suitable for deduplication?
ZFS Deduplication
Provides general information on ZFS deduplication in TrueNAS, hardware recommendations, and useful deduplication CLI commands.
