mircsicz
- May 11, 2013
Hi there,
installed a Debian jail, and can't upgrade it:
By manually commenting out some parts of:
/var/lib/dpkg/info/initscripts.postinst
and manually running:
dpkg --configure initscripts
I got it to work...
But to finish the upgrade I had to remove "grub-pc"
So if there's a way to modify the template I'ld be very willing to get that template on a more reliable state...
Greetz
Mircsicz
BTW: I already read through this one: http://forums.freenas.org/index.php?threads/jail-templates.14478/
(Reading database ... 25437 files and directories currently installed.) Preparing to replace initscripts 2.88dsf-41+deb7u1 (using .../initscripts_2.88dsf-41+deb7u1_i386.deb) ... Unpacking replacement initscripts ... Setting up initscripts (2.88dsf-41+deb7u1) ... mount: unknown filesystem type 'none' dpkg: error processing initscripts (--install): subprocess installed post-installation script returned error exit status 1 Processing triggers for man-db ... fopen: Permission denied Errors were encountered while processing: initscripts
I got it to work...
Greetz
Mircsicz
