Datasets and zVol
BlazeStar
So my FreeNAS box is running.
I've created Volumes.
Now I was during the process of creating shares.
But then I saw this :
http://doc.freenas.org/index.php/Quick_Start_Guide#Configure_Storage
Which referred to Datasets and Zvol :
http://doc.freenas.org/index.php/Volumes#Creating_ZFS_Datasets
http://doc.freenas.org/index.php/Volumes#Creating_a_zvol
The guide describes perfectly how to manage that... however I'm still wondering WHY I would use Datasets or Zvol?
On the topic of Datasets, it is said (in the guide) that :
An existing ZFS volume can be divided into datasets. Permissions, compression, deduplication, and quotas can be set on a per dataset basis, allowing more granular control over access to storage data. A dataset is similar to a folder in that you can set permissions; it is also similar to a filesystem in that you can set properties such as quotas and compression as well as create snapshots.
I'm not sure if and why I should datasets!
I mean... by using shares, I can pretty much do the same things!
Am I missing something?
diedrichg
Do you want your sibling or parent to have access to your files? If not, then you will want to set up datasets. You could then also set up a shared dataset. Datasets can also be nested for shared/walled access.
Sent from my SGH-I337 using Tapatalk
BlazeStar
Well, I don't see how a dataset would prevent that... all folders can be set up as different shares.
Each share has different read / write access, and can be set based on user groups, or users!
That's so not true. You can setup folders to prevent access too. The question is "do datasets do something folders don't that you want".
BlazeStar
Not sure I understand your response, Cyberjock...
But if I do: Yes, the question would be "Do datasets do anything that shared folders don't?"
Yep.. ZFS separation and ZFS properties...
