phil465132
- Aug 27, 2022
Noticed my data pool was offline, and I believe it was the same day I inserted my new device for charging into one of the usb ports. Maybe it has some internal storage and threw things off?
storage - data1 pool - offline
should be 5 disks.
sda-sdd show the correct size
sde shows a weird serial number and 0B disk size.
If I run smartctl --scan, I do not see sde even listed.
If I run zpool status or zpool list, I only see boot-pool and not data1.
If I try to wipe sde, I see error message "no medium found"
Software: TrueNas Scale 22.02.04
CPU: intel i5-9400
Motherboard: asrock b365m pro4
RAM: 16 GB
HD 5x samsung 1t ssd (I think mostly 860 evo), boot is 960 samsung evo
zfs config - sorry dont remember, thought I did z1 but not sure.
Can anyone steer me on recovery, or at least getting the pool back online and usable.
Appreciate any pointers you can provide.
Happy to provide any other info, run any commands, etc.
should be 5 disks.
CPU: intel i5-9400
RAM: 16 GB
