Custom reporting metrics
Apprisco
For example, I want to add the temperature output of NVIDIA-SMI and HBA temperature from storcli /c0 show all nolog | sed -n -r -e 's/^ROC temperature\(Degree ([CF])[[:alpha:]]+\) = ([[:digit:]]+)$/\2 \1/p'
To the reporting metrics, either the main dashboard or in Reporting section.
Is there any app that allows you to add more things to the dashboard or reporting?
Thanks!
No, not exactly that.
Maybe what you're looking for is netdata?
Apprisco
I just want to add custom metrics for temperature for my HBAs in Reporting if possible. Seems like TrueCommand is the only way but I don't want to have to use TrueCommand and be potentially locked out of my self hosted things.
I don't see how TrueCommand would allow that... but why would that lock you out of self-hosting (if you self host TrueCommand also)?
Apprisco
I simply don't like that TrueCommand is separate from TrueNAS Scale, and requires a subscription for over 50 drives.
I can use TrueCommand as an app in Scale, and TrueCommand allows for custom reporting metrics in TrueCommand (not the scale dashboard probably.)
