Chris Moore
- May 2, 2015
You can use the system board SATA ports for the boot drives. Data drives will all be connected to the SAS HBA.Will it take one of the ports for the HDDs though?
...and I've had eight out of six "white label" drives that I bought from them [goharddrive] fail. They did replace them promptly, but that failure rate is far too high for me to do that again.
The regular SATA port on the system board are just like any other SATA port. Nothing special.Good point!
What cables do I need for this configuration? I probably have none that are usable with this server, I might have a bunch of sata cables laying somewhere in the closet, but that's all I have.
I have no idea how a SAS cable look, I only built desktop PCs in my life!
I'll agree that they were very prompt and easy to work with on warranty issues. They also did advance exchanges on my request, and without charging me anything (WD does advance exchanges, though they charge a nominal fee for the service). Although OEM warranty claims I've made in recent years have been nearly as prompt and responsive, albeit without prepaid return shipping.FWIW, I had one out of 9 drives fail. I noted the error in an email to them and I got a prompt prepaid return shipping label within 12 hours
Hello Chris,The RAM I suggested should be fine for either CPU because I suggested PC3L-12800R, which is supported by both processors and the system board. If you went with the marginally faster 1866 MHz memory, you would NEED the v2 CPU .
They are both "rated" for 130 watts, but the v1 CPU does draw more current and create more heat. I don't know exactly what the difference is, and it would depend on demand. My NAS sits idle most of the time and the heavy CPU load is when I am running a scrub on the array or copying a lot of data from one pool to another. Plex almost never goes over 10% on CPU utilization.
You say Xeon E5-2667 V1 vs Xeon E5-2650 V2... I would say the V2 is actually a better processor because it is newer. Then you ask,Due to a misunderstanding, I ended up with an E5-2650 V2 instead of a 2667 V1.
How worse the CPU is?
A Xeon E5-2667 V2 is a much faster, more expensive, processor than the other two that you mentioned.Should I consider purchasing a pair of 2667 V2?
I found it here for $208.66 each:
https://www.ebay.com/itm/Intel-Xeon...or-Single-Max-4-0GHz-LGA2011-CPU/302845862529
Where the Xeon E5-2650 v2 is available here for $74.99 each:
https://www.ebay.com/itm/SR1A8-INTE...-CACHE-8-CORE-LGA-2011-PROCESSOR/183022002957
Where the Xeon E5-2667 V1 is available here for $88 each:
https://www.ebay.com/itm/Pair-of-In...FCLGA2011-CPU-6-Cores-2-9-3-5GHz/123617259919
You must be very specific about those model numbers.
Maybe, and most likely not, but it depends on exactly what hardware you ended up with. I know that there was some discussion, but I don't know exactly what you ended up getting. Can you give some feedback on what you have, possibly even some photos?Sorry another question, I bought this cable for the HP H220 card you suggested: https://www.amazon.ca/gp/product/B0736MXQ3Q/ref=ppx_yo_dt_b_asin_title_o08__o00_s00?ie=UTF8&psc=1
I assume I have to connect each SATA cable to one HDD (my hdds are common wd red).
How many of those cables do I need to cover all 24, do I need 6 of those cables?
And if yes, do I also need 3 of those cards?
I went back through the thread and the last two server chassis we looked at had SAS expander modules integrated in the hot-swap backplane so you would not need a separate SAS expander card and you would not need the forward breakout cables.
The third one allows you to up-link from this backplane to another if you had a chassis with two backlanes, like this one:On the backplane there are 2 plugs for the SAS cables that are close. there is a third one far to the right though. I'm not sure what the purpose of that one is, but since the raid card was using only the 2 close ones, I assume this is still the configuration.
Oh, amazing all these things!The third one allows you to up-link from this backplane to another if you had a chassis with two backlanes, like this one:
https://www.ebay.com/itm/Supermicro...-3-06hz-12-Cores-128gb-SAS2-Raid/292932846269
I can't recall if I shared this with you, but you might want to take a look at these resources:Looks I'm all set, thanks a lot, I'll let you know how it goes in the next few days. If you don't hear back, the server exploded and brought down the whole house :p
Yep you did, I check them in your signature (I read various guides from there)I can't recall if I shared this with you, but you might want to take a look at these resources:
Uncle Fester's Basic FreeNAS Configuration Guide
https://www.familybrown.org/dokuwiki/doku.php?id=fester:intro
Github repository for FreeNAS scripts, including disk burnin
https://forums.freenas.org/index.ph...for-freenas-scripts-including-disk-burnin.28/
If you learn interesting things, you must share.Server is healthy and I'm much happier with this. IPMI was a great surprise and I've been learning a lot of new interesting things. Thanks!
Absolutely, but I assume most things I discovered are well known, I never used an enterprise software so even IPMI was amazing. I found incredibly interesting the fact that servers are much easier to build than consumer pcsIf you learn interesting things, you must share.
