- Aug 16, 2011
A couple of weeks ago, I started getting warning emails from my FreeNAS server that a disk was starting to show current/pending sectors.  Looking at the SMART data, item 197 was at 5.  Figuring this was a sign of the disk failing, I obtained a replacement disk, tested it, and installed it in my server.  The array is resilvered and working without issue.
With that taken care of, I installed the old, believed-failing disk in another server and ran a full badblocks scan on it, which took a few days. After that, I pulled the SMART data again (below). To my surprise, item 197 is now 0. I'd figured, if anything, that the value would increase, with badblocks forcing repeated r/w to each sector on the disk. Can I trust this disk? I doubt I could RMA it with no errors showing.
[root@e-smith ~]# smartctl -a /dev/sdc
smartctl 5.43 2012-06-30 r3573 [x86_64-linux-2.6.32-431.29.2.el6.x86_64] (local build)
Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net
Device Model:     WDC WD30EFRX-68EUZN0
Serial Number:    WD-WCC4N1112375
LU WWN Device Id: 5 0014ee 20a20083a
Firmware Version: 80.00A80
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   8
ATA Standard is:  ACS-2 (revision not indicated)
Local Time is:    Thu Sep 25 10:40:21 2014 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)Offline data collection activity
was never started.
Self-test execution status:      (   0)The previous self-test routine completed
been run.
data collection: (39240) seconds.
capabilities:  (0x7b) SMART execute Offline immediate.
command.
Self-test supported.
SMART capabilities:            (0x0003)Saves SMART data before entering
power-saving mode.
Error logging capability:        (0x01)Error logging supported.
Short self-test routine
recommended polling time:  (   2) minutes.
Extended self-test routine
recommended polling time:  ( 394) minutes.
Conveyance self-test routine
recommended polling time:  (   5) minutes.
SCT capabilities:        (0x703d)SCT Status supported.
SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       87
  3 Spin_Up_Time            0x0027   180   180   021    Pre-fail  Always       -       5966
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       7
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   097   097   000    Old_age   Always       -       2783
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       7
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       5
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       10
194 Temperature_Celsius     0x0022   118   110   000    Old_age   Always       -       32
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%      2677         -
# 2  Extended offline    Completed without error       00%      2663         -
# 3  Short offline       Completed without error       00%      2653         -
# 4  Short offline       Completed without error       00%      2629         -
# 5  Short offline       Completed without error       00%      2605         -
# 6  Short offline       Completed without error       00%      2581         -
# 7  Short offline       Completed without error       00%      2557         -
# 8  Short offline       Completed without error       00%      2533         -
# 9  Short offline       Completed without error       00%      2509         -
#10  Extended offline    Completed without error       00%      2495         -
#11  Short offline       Completed without error       00%      2485         -
#12  Short offline       Completed without error       00%      2461         -
#13  Short offline       Completed without error       00%      2437         -
#14  Short offline       Completed without error       00%      2413         -
#15  Short offline       Completed without error       00%      2389         -
#16  Short offline       Completed without error       00%      2367         -
#17  Short offline       Completed without error       00%      2341         -
#18  Extended offline    Completed without error       00%      2327         -
#19  Short offline       Completed without error       00%      2317         -
#20  Short offline       Completed without error       00%      2293         -
#21  Short offline       Completed without error       00%      2269         -
