Cron job help
Victor87
Hello all
I try to add an cron job on truenas scale to grab automatic the epg with webgrabplus app installed from truechart.
If I run the command "/defaults/update.sh" in the pod shell of the webgrab app, everything works perfect. It will look like this: "root@webgrabplus-696c8d9dc8-8f7ls:/# /defaults/update.sh".
But on the cron job all the path what I was trying to add it always fail with error "no such file or directory".
How can I find the correct path of the file?
Thanks
1. Make sure the file has execute permission
chmod a+x {filename}
2. Prefix the CRON task with
/bin/sh {path/filename}
Victor87
I'm beginner and I don't understand very well all the stuff
If I run "chmod a+x update.sh" or "chmod a+x defaults/update.sh"on shell it says no such file or directory.
On shell pod it looks like in the picture.
Also on cron job with comand "/bin/sh default/update.sh" it doesn't find the path or directory
I test with and without. You mean /defaults/update.sh? Doesn't work
I am guessing you don't have the shell shebang in the header of the file.
#!/bin/sh
Victor87
#!/bin/sh
Means that the command in Cron job must look like this?
#!/bin/sh /defaults/update.sh
Or you mean on the wg3-cron file from webgrabplus app? Picture attached
