Critical Alert
solNAS
Hi there,
yesterday I got the attached message by e-mail.
I had no access via the webserver any more. The smb-volumes were still available.
After rebooting the system I cannot reach neither the webserver nor the smb-volumes.
The report ist that extensive that I am overchallanged.
Pls. can you give me a hint which problem this report tells me.
I am afraid that it is one of the hard disks or the USB-boot-stick (once more)..
thank you in advance.
br TC
  • TemplateDoesNotExist at _account_login_.txt
D
dlavigne
Guest
Do you know if the system has the latest SU installed? If so, please create a bug report at bugs.freenas.org that includes that attachment and post the issue number here.
In the meantime, you should be able to boot into a different BE, but you will need console or IPMI access to select it from the boot menu.
solNAS
yes it is the latest SU.
I wasn't able to boot and thus couldn't do any analysis via command line-> immediate redirection into BIOS
I found an USB- Stick in my treasure box.
Create a new OS stick.
System works.
Seems to be a problem with either the mainboard or the sticks (already two Kingston DT101G2 8GB Sticks destroyed in this NAS)
Problem is solved.
It was a hardware issue- USB Stick damaged.
Thank you for your help.
