Hi guys.
I just setup TrueNAS 13.0-U3 today. I just noticed there is no option, on my dashboard, for "Credentials"? From the manual:
Once I have an option to enter "Credentials", I'd like to use sync.com for my cloud storage provider. Will TrueNAS support sync.com natively? It was not in the list of (3) that I did find to be supported. I did find reference to people using sync.com on this forum. I'm just not sure how they made it work.
Thanks to all, in advance, for your time and consideration. I look forward to your response(s).
Cloud Sync Task Requirements
- You must have all system storage configured and ready to receive or send data.
- You must have a cloud storage provider account and location (like an Amazon S3 bucket).
