ukzerosniper
- Mar 1, 2013
Hi Guys,
When I create LACP with 4x NIC the system always crashes immediatly.
I am running FreeNAS 8.3.0
FreeNAS is installed to an 8Gb USB Drive
The server hardware is a HP DL380, 2x XEON 3.6GHz, 1GB RAM, 1x 76GB Hard Disk.
I know we need a ton more RAM and still need to install the other 5 Hard Disks, however at the moment, im just trying to get the main OS setup and running.
Attached is a photo of the output at crash, this happens as soon as I create the LACP and add the 4x NIC then tell the new connection to be a DHCP client. As soon as I ok the DHCP client check box it crashes. It gives the same crash if I do this via the gui or command line.
Any ideas are gratefully received.
Also, im not sure why it has put the image upside down???? It is the correct way up on my pc and when i uploaded it :/. Sorry about that. Below is a link to the image on my skydrive.
http://sdrv.ms/WATO2R
Thanks
Thanks
