Hi, im using truenas scale for about 1 month, and now Im trying to make a simple gaming vm, but im having a lot of issues creating a vm,
when I try to create a vm with the gpu, it give me an error about enable the iommu, sometime idk why, that error doesn't appear, but when I "created" that vm, I cannot connect for example through "parsec", or if I connect with the vnc, sometime it disconnect from it, and im stuck with a resolution of 800x600, im unable to change it, even if I edit in the devices the resolution. i have the same issue even for windows server 2019, same issues, is there a way to fix that?
