I can install mini dlna plugins without problem, but when installing transmission plugins, the system crash.
I tryied to create a jail whith "plugins jail" settings, named "transmission", the system crash.
my system come from 8.2-i386, I just upgraded on 9.2-x64
bellow the serial console, if you have any idea...
FreeBSD/amd64 (SS4200.rem-s.net) (ttyu0)
Console setup
1) Configure Network Interfaces
2) Configure Link Aggregation
3) Configure VLAN Interface
4) Configure Default Route
5) Configure Static Routes
6) Configure DNS
7) Reset WebGUI login credentials
8) Reset to factory defaults
9) Shell
10) Reboot
11) Shutdown
You may try the following URLs to access the web user interface:
http://192.168.1.202
https://192.168.1.202
Enter an option from 1-11: epair1a: Ethernet address: 02:55:7a:00:0b:0a
epair1b: Ethernet address: 02:55:7a:00:0c:0b
Fatal trap 12: page fault while in kernel mode
cpuid = 0; apic id = 00
fault virtual address = 0x0
fault code = supervisor read instruction, page not present
instruction pointer = 0x20:0x0
stack pointer = 0x28:0xffffff809c7038f0
frame pointer = 0x28:0xffffff809c703940
code segment = base 0x0, limit 0xfffff, type 0x1b
= DPL 0, pres 1, long 1, def32 0, gran 1
processor eflags = interrupt enabled, resume, IOPL = 0
current process = 8734 (ifconfig)
[ thread pid 8734 tid 100556 ]
Stopped at 0: *** error reading from address 0 ***
db:0:kdb.enter.default> watchdog 38
db:0:kdb.enter.default> textdump set
textdump set
db:0:kdb.enter.default> capture on
db:0:kdb.enter.default> show allpcpu
Current CPU: 0
cpuid = 0
dynamic pcpu = 0x398700
curthread = 0xfffffe0056f5f000: pid 8734 "ifconfig"
curpcb = 0xffffff809c703d00
fpcurthread = none
idlethread = 0xfffffe00024e4000: tid 100003 "idle: cpu0"
curpmap = 0xfffffe004e05ba60
tssp = 0xffffffff8132ec80
commontssp = 0xffffffff8132ec80
rsp0 = 0xffffff809c703d00
gs32p = 0xffffffff8132cdb8
ldt = 0xffffffff8132cdf8
tss = 0xffffffff8132cde8
curvnet = 0xfffffe00023ea200
db:0:kdb.enter.default> bt
Tracing pid 8734 tid 100556 td 0xfffffe0056f5f000
uart_sab82532_class() at 0/frame 0xffffff809c703940
ifioctl() at ifioctl+0x875/frame 0xffffff809c703a60
kern_ioctl() at kern_ioctl+0x106/frame 0xffffff809c703ab0
sys_ioctl() at sys_ioctl+0xfd/frame 0xffffff809c703b10
amd64_syscall() at amd64_syscall+0x62e/frame 0xffffff809c703c30
Xfast_syscall() at Xfast_syscall+0xf7/frame 0xffffff809c703c30
--- syscall (54, FreeBSD ELF64, sys_ioctl), rip = 0x800f6491c, rsp = 0x7fffffffd488, rbp = 0x3 ---
db:0:kdb.enter.default> ps
pid ppid pgrp uid state wmesg wchan cmd
8739 8579 2532 0 R ifconfig
8734 8724 1470 0 R CPU 0 ifconfig
8724 1470 1470 0 S wait 0xfffffe005bf1e000 sh
8579 8578 2532 0 S wait 0xfffffe005bf1e4b8 sh
8578 8542 2532 0 S wait 0xfffffe004b4a9000 lockf
8542 2533 2532 0 S wait 0xfffffe004b6394b8 sh
7381 5394 7381 0 S+ select 0xfffffe004e07ebc0 top
6777 6080 2532 0 S nanslp 0xffffffff812c5648 sleep
6080 1 2532 0 S wait 0xfffffe004e0704b8 sh
5815 1 5815 0 Ss (threaded) collectd
100584 S uwait 0xfffffe0049ae5580 collectd
100583 S uwait 0xfffffe0049b1dc00 collectd
100582 S uwait 0xfffffe0049acaa00 collectd
100581 S uwait 0xfffffe0049ae1600 collectd
100580 S uwait 0xfffffe0049ac6a00 collectd
100579 S uwait 0xfffffe0049a66600 collectd
100578 S uwait 0xfffffe004ae5a580 collectd
100577 S uwait 0xfffffe004ae5a500 collectd
100576 S uwait 0xfffffe0049ae0700 collectd
100575 S uwait 0xfffffe0049ad5500 collectd
100574 S uwait 0xfffffe0049ac9000 collectd
100081 S nanslp 0xffffffff812c5648 collectd
5808 1 20 0 S nanslp 0xffffffff812c5648 sleep
5394 5210 5394 0 Ss+ pause 0xfffffe0056f5da18 csh
5210 4987 5210 0 Ss select 0xfffffe004e07ea40 sshd
5133 1 5133 0 Ss+ ttyin 0xfffffe00078038a8 python2.7
5132 1 5132 0 Ss+ ttyin 0xfffffe000780c4a8 getty
5131 1 5131 0 Ss+ ttyin 0xfffffe000780c8a8 getty
5130 1 5130 0 Ss+ ttyin 0xfffffe000780cca8 getty
5129 1 5129 0 Ss+ ttyin 0xfffffe00078078a8 getty
5128 1 5128 0 Ss+ ttyin 0xfffffe000780aca8 getty
5127 1 5127 0 Ss+ ttyin 0xfffffe000780a0a8 getty
5126 1 5126 0 Ss+ ttyin 0xfffffe000780a4a8 getty
5125 1 5125 0 Ss+ ttyin 0xfffffe000780a8a8 python2.7
4991 1 4991 0 Ss nanslp 0xffffffff812c5648 cron
4987 1 4987 0 Ss select 0xfffffe004ae5a4c0 sshd
4578 4576 4576 80 SJ accept 0xfffffe0056a39066 php-fpm
4577 4576 4576 80 SJ accept 0xfffffe0056a39066 php-fpm
4576 1 4576 0 SsJ kqread 0xfffffe0056c0bb00 php-fpm
4394 1 4394 0 SsJ nanslp 0xffffffff812c5648 cron
4387 1 4387 933 SsJ select 0xfffffe0056a91cc0 minidlnad
4339 1 4339 0 SsJ select 0xfffffe004b17d1c0 syslogd
3082 1 3081 200 S select 0xfffffe0049ac68c0 avahi-daemon
3078 1 3078 201 Ss select 0xfffffe000cdae2c0 dbus-daemon
3030 3028 3028 80 S kqread 0xfffffe004b4d1200 nginx
3028 1 3028 0 Ss pause 0xfffffe004b4a9560 nginx
2533 1 2532 0 S (threaded) python2.7
100524 S usem 0xfffffe004ae5a300 python2.7
100523 S usem 0xfffffe0049aca480 python2.7
100522 S usem 0xfffffe000cda1180 python2.7
100521 S select 0xfffffe0056bff840 python2.7
100520 S usem 0xfffffe0049ac6c80 python2.7
100511 S select 0xfffffe0049a8f940 python2.7
2378 1 2377 0 S nanslp 0xffffffff812c5648 smartd
2376 2371 2371 0 S select 0xfffffe0049ac1940 smbd
2371 1 2371 0 Ss select 0xfffffe0049ac9240 smbd
2368 1 2368 0 Ss select 0xfffffe000cdae640 nmbd
2264 1 2264 0 Ss select 0xfffffe0013825a40 proftpd
1966 1 1966 0 Ss select 0xfffffe0049ac1ac0 ntpd
1766 1 1766 0 Ss nanslp 0xffffffff812c5648 watchdogd
1756 1 1756 0 Ss select 0xfffffe0049ac61c0 syslogd
1470 1 1470 0 Ss wait 0xfffffe0013516970 devd
667 0 0 0 DL ftcl 0xffffffff81a145c8 [ftcleanup]
306 0 0 0 DL geli:w 0xfffffe001322cc00 [g_eli[0] ada3p1]
304 0 0 0 DL geli:w 0xfffffe001322c000 [g_eli[0] ada2p1]
302 0 0 0 DL geli:w 0xfffffe000ce50800 [g_eli[0] ada1p1]
300 0 0 0 DL geli:w 0xfffffe000ce50400 [g_eli[0] ada0p1]
272 0 0 0 DL (threaded) [zfskern]
100501 D tx->tx_s 0xfffffe00139f5a08 [txg_thread_enter]
100500 D tx->tx_q 0xfffffe00139f5a28 [txg_thread_enter]
100494 D spa->spa 0xfffffe0013ff8ac0 [trim zetta]
100079 D l2arc_fe 0xffffffff81983840 [l2arc_feed_thread]
100068 D arc_recl 0xffffffff819739a0 [arc_reclaim_thread]
200 0 0 0 DL gkt:wait 0xffffffff818415a4 [g_mp_kt]
57 0 0 0 DL mdwait 0xfffffe0007815000 [md2]
47 0 0 0 DL mdwait 0xfffffe00026e7800 [md1]
37 0 0 0 DL mdwait 0xfffffe000cd47800 [md0]
19 0 0 0 DL sdflush 0xffffffff81321500 [sof+0x194/frame 0xffffff809c6b8930
sleepq_catch_signals() at sleepq_catch_signals+0x363/frame 0xffffff809c6b8990
sleepq_timedwait_sig() at sleepq_timedwait_sig+0x19/frame 0xffffff809c6b89c0
_sleep() at _sleep+0x2f3/frame 0xffffff809c6b8a30
do_wait() at do_wait+0x716/frame 0xffffff809c6b8ad0
__umtx_op_wait_uint_private() at __umtx_op_wait_uint_private+0x6e/frame 0xffffff809c6b8b10
amd64_syscall() at amd64_syscall+0x62e/frame 0xffffff809c6b8c30
Xfast_syscall() at Xfast_syscall+0xf7/frame 0xffffff809c6b8c30
--- syscall (454, FreeBSD ELF64, sys__umtx_op), rip = 0x800a6e4ec, rsp = 0x7ffffe9f4ee8, rbp = 0 ---
Tracing command collectd pid 5815 tid 100582 td 0xfffffe004b4cf490
sched_switch() at sched_switch+0x137/frame 0xffffff809c6b38e0
mi_switch() at mi_switch+0x194/frame 0xffffff809c6b3930
sleepq_catch_signals() at sleepq_catch_signals+0x363/frame 0xffffff809c6b3990
sleepq_timedwait_sig() at sleepq_timedwait_sig+0x19/frame 0xffffff809c6b39c0
_sleep() at _sleep+0x2f3/frame 0xffffff809c6b3a30
do_wait() at do_wait+0x716/frame 0xffffff809c6b3ad0
__umtx_op_wait_uint_private() at __umtx_op_wait_uint_private+0x6e/frame 0xffffff809c6b3b10
amd64_syscall() at amd64_syscall+0x62e/frame 0xffffff809c6b3c30
Xfast_syscall() at Xfast_syscall+0xf7/frame 0xffffff809c6b3c30
Console setup
6) Configure DNS
9) Shell
10) Reboot
11) Shutdown
textdump set
Current CPU: 0
cpuid = 0
fpcurthread = none
