SOLVED CPU Utilisation
GastonJ
Good evening.
I just added a further NIC to my Truenas Scale server, restarted and CPU utilisation was very high. Thinking this was related to the new NIC I downed the server and removed the NIC. Restarted. CPU utilisation is still very high
From top
Oddly enough it's just settled down to it's usual relaxed self, after about 10 minutes.
Though I really would appreciate some pointers of what may have been causing the issue. I think I've attached everything that's needed. Wanting to resolve this due to wanting to virtualise my firewall onto it (hence the new NIC)
Cheers
  • k3s_daemon_log.txt
  • containerd_log.txt
  • messages.txt
  • dmesg.txt
  • daemon_log.txt
GastonJ
Just to update this
DMAR: DRHD: handling fault status reg 2
from dmesg is related to the HP Broadcom network driver and shared memory. (or I disable intel_iommu=on) I'll fix teh shared memory issue, I want IOMMU on for my VM.
[Firmware Bug]: the BIOS has corrupted hw-PMU resources (MSR 38d is 330)
is just for info, rather than having an impact. HP - what more can you say
DMAR: [Firmware Bug]: No firmware reserved region can cover this RMRR [0x00000000000e8000-0x00000000000e8fff], contact BIOS vendor for fixes
Doesn't look relevant
ACPI: SPCR: Unexpected SPCR Access Width. Defaulting to byte size
No impact again
So I'm not seeing anything of concern in dmesg output.
LarsR
One of the first things scale does after a reboot is syncing the apps catalogues, which cause high cpu usage.
If you've added truecharts it can take up to 5 minutes.
GastonJ
Thank you. I've never really watched it boot before, I just press the start switch, go make coffee and so on before I look. I'll drop the card back in later and leave it 10 minutes before I look.
Thanks
GastonJ
Just installed the new NIC and no problems. Onwards and upwards as they say. Thank you.
