I have an AMD system with an AMD Epyc 7302P (16C/32T over 4 CCDs; 4 cores per CCD) and I'd like to monitor CPU temperature using the graphite server reporting feature in TrueNAS 13.0 U4.
If I enable the graphite reporting feature, I get 32 temperature readings in database with names like:
If I check with
So it seems those values come from there. Is there any way to read the temperatures from the individual cores?
For instance,
At least there are individual readings from the individual CCDs, but I have no clue why this is repeated 4 times?!
Anyway, those
The dashboard isn't working correctly either. All CPU threads have the same temperature:
servers.<server_name>.cputemp.<core#>.temperature, but they all report the exact same value.If I check with
sysctl, I get something like this:Code:
dev.cpu.31.temperature: 51.7C dev.cpu.30.temperature: 51.7C dev.cpu.29.temperature: 51.7C dev.cpu.28.temperature: 51.7C dev.cpu.27.temperature: 51.7C dev.cpu.26.temperature: 51.7C dev.cpu.25.temperature: 51.7C dev.cpu.24.temperature: 51.7C dev.cpu.23.temperature: 51.7C dev.cpu.22.temperature: 51.7C dev.cpu.21.temperature: 51.7C dev.cpu.20.temperature: 51.7C dev.cpu.19.temperature: 51.7C dev.cpu.18.temperature: 51.7C dev.cpu.17.temperature: 51.7C dev.cpu.16.temperature: 51.7C dev.cpu.15.temperature: 51.7C dev.cpu.14.temperature: 51.7C dev.cpu.13.temperature: 51.7C dev.cpu.12.temperature: 51.7C dev.cpu.11.temperature: 51.7C dev.cpu.10.temperature: 51.7C dev.cpu.9.temperature: 51.7C dev.cpu.8.temperature: 51.7C dev.cpu.7.temperature: 51.7C dev.cpu.6.temperature: 51.7C dev.cpu.5.temperature: 51.7C dev.cpu.4.temperature: 51.7C dev.cpu.3.temperature: 51.7C dev.cpu.2.temperature: 51.7C dev.cpu.1.temperature: 51.7C dev.cpu.0.temperature: 51.7C
For instance,
sysctl has some entries from amdtemp as well. Something likle this:Code:
dev.amdtemp.3.ccd6: 51.5C dev.amdtemp.3.ccd4: 49.6C dev.amdtemp.3.ccd2: 54.6C dev.amdtemp.3.ccd0: 47.5C dev.amdtemp.3.core0.sensor0: 51.7C dev.amdtemp.3.sensor_offset: 0 dev.amdtemp.3.%parent: hostb32 dev.amdtemp.3.%pnpinfo: dev.amdtemp.3.%location: dev.amdtemp.3.%driver: amdtemp dev.amdtemp.3.%desc: AMD CPU On-Die Thermal Sensors dev.amdtemp.2.ccd6: 51.5C dev.amdtemp.2.ccd4: 49.6C dev.amdtemp.2.ccd2: 54.6C dev.amdtemp.2.ccd0: 47.5C dev.amdtemp.2.core0.sensor0: 51.7C dev.amdtemp.2.sensor_offset: 0 dev.amdtemp.2.%parent: hostb16 dev.amdtemp.2.%pnpinfo: dev.amdtemp.2.%location: dev.amdtemp.2.%driver: amdtemp dev.amdtemp.2.%desc: AMD CPU On-Die Thermal Sensors dev.amdtemp.1.ccd6: 51.5C dev.amdtemp.1.ccd4: 49.6C dev.amdtemp.1.ccd2: 54.6C dev.amdtemp.1.ccd0: 47.5C dev.amdtemp.1.core0.sensor0: 51.7C dev.amdtemp.1.sensor_offset: 0 dev.amdtemp.1.%parent: hostb8 dev.amdtemp.1.%pnpinfo: dev.amdtemp.1.%location: dev.amdtemp.1.%driver: amdtemp dev.amdtemp.1.%desc: AMD CPU On-Die Thermal Sensors dev.amdtemp.0.ccd6: 51.5C dev.amdtemp.0.ccd4: 49.6C dev.amdtemp.0.ccd2: 53.5C dev.amdtemp.0.ccd0: 47.5C dev.amdtemp.0.core0.sensor0: 51.7C dev.amdtemp.0.sensor_offset: 0 dev.amdtemp.0.%parent: hostb0 dev.amdtemp.0.%pnpinfo: dev.amdtemp.0.%location: dev.amdtemp.0.%driver: amdtemp dev.amdtemp.0.%desc: AMD CPU On-Die Thermal Sensors dev.amdtemp.%parent:
Anyway, those
amdtemp readings do not show up in the graphite server. Is there any way to get those amdtemp values to the graphite server without scripting this myself?The dashboard isn't working correctly either. All CPU threads have the same temperature:
