correct names for jail templates?
32smooth
while trying to install the plex mediaserver plugin I accidently deleted the jail templates. I reinstalled the templates but when trying to install the plex plugin I get:
Mar 14 17:13:00 freenas manage.py: [middleware.exceptions:38] [MiddlewareError: Unable to find template!]
I fear I used the wrong names for the jail templates. Can anyone give the correct names for the
http://download.freenas.org/jails/9.3/x64/freenas-standard-9.3-RELEASE.tgz
and
http://download.freenas.org/jails/9.3/x64/freenas-pluginjail-9.3-RELEASE.tgz
templates?
many thanks in advance,
Torsten
32smooth
please - can anyone tell me the name for the pluginjail?
SweetAndLow
Sweet'NASty
You went into the CLI and delete the template didn't you? If this is true then you also need to remove the mount point where the template is. What is the output of zfs list.
32smooth
Hello Sweet, thanks for the reply. I didn't usw CLI to delete the template, I used the GUI.
zfs list:
[root@freenas] ~# zfs list
NAME USED AVAIL REFER MOUNTPOINT
Main 6.44T 1.46T 1.99T /mnt/Main
Main/.system 313M 1.46T 296M legacy
Main/.system/cores 15.2M 1.46T 15.2M legacy
Main/.system/rrd-918d6d1d2f4441c185ba32ed251d37b2 144K 1.46T 144K legacy
Main/.system/rrd-c781aa6ebd25484c8281ae9d2b2c944c 96K 1.46T 96K legacy
Main/.system/samba4 368K 1.46T 368K legacy
Main/.system/syslog-918d6d1d2f4441c185ba32ed251d37b2 692K 1.46T 692K legacy
Main/.system/syslog-c781aa6ebd25484c8281ae9d2b2c944c 596K 1.46T 596K legacy
Main/Media 4.45T 1.46T 4.45T /mnt/Main/Media
Main/jails 84.3M 1.46T 84.3M /mnt/Main/jails
freenas-boot 4.84G 9.21G 31K none
freenas-boot/ROOT 4.82G 9.21G 31K none
freenas-boot/ROOT/FreeNAS-201412021601 590K 9.21G 931M /
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201412240734 560K 9.21G 932M /
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201501090144 816K 9.21G 933M /
freenas-boot/ROOT/FreeNAS-9.3-STABLE-201502271818 4.82G 9.21G 926M /
freenas-boot/ROOT/FreeNAS-FreeNAS-9.3-BETA-201412090235 450K 9.21G 932M /
freenas-boot/ROOT/default 311K 9.21G 929M legacy
freenas-boot/grub 8.04M 9.21G 7.79M legacy
[root@freenas] ~#
Thanks,
Torsten
*You* don't use the incorrect template name. The problem is you deleted the template after the system created it. Since it wasn't deleted properly (hint: You actually have to do it from the CLI using warden) you're in this crappy situation where warden expects a template where non exists.
I'm pretty sure you can't just extract the template back where the template was and expect it to work. You're probably going to have to do some warden crap from the CLI to recover from this, but that's beyond what I'm going to try to work with you on in the forum. Doing stuff from the CLI with warden can end very badly if the person playing with warden can't identify, fully, the problem and proper solution.
Robert Riedel
I did the same thing and deleted the template. If you just record all your other settings (I wrote them down) and do a factory reset. Then just re-enter your settings and you are good to go.
diskdiddler
I do not have a "pluginjail" template, never have? I upgraded from 9.2 how does one install it?
