"copy speed"
carlo5369
Hi
I have a FreeNAS-9.10.2-U1 that when I copy from a windows server about 60Gb of files speed goes to something like 10Kb/s.
Some files same server to a network client about 10Mb/s
What can I check?
thank you in advance.
Carlo
Chris Moore
You can tell us what hardware configuration you have for your FreeNAS system. The hardware you are using and the arrangement of the disks will have a large influence on the potential performance.
Chris Moore
carlo5369
Hi
here's a brief description
Versione FreeNAS-9.10.2-U1 (86c7ef5)
Piattaforma AMD Phenom(tm) II X2 B55 Processor
Mermory 7650MB
2 disks WD 6tb in raid 1
this are alle the info I have at the moment. Nas are build not from my unit, they usally take "old" hp client ... still the same thats the question ... similar (or identical) nas have different speed
Tomorrow I will check for more detailed info about hardware.
