Converting VirtualBox VM to FreeNAS 11 VM
Patrick M. Hausen
Anything interesting when you enter these into your EFI shell?
fs0:
dir
bignellrp
Patrick M. Hausen
There is no EFI partition on that disk image so you cannot boot it. Install Ubuntu with EFI boot ...
Or try what I outlined above - add a second disk with rEFInd on it.
bignellrp
Thanks. That worked.
Just in case this helps anyone else with this issue here are the steps i followed;
  • Follow steps from this guide to create the raw file of your VM.
  • Create the zvol slightly larger that the raw image.
  • DD the raw into the zvol.
  • Create a VM with the zvol as the disk and Ubuntu Desktop live cd as the cdrom.
  • Boot into Ubuntu Desktop
  • Open a search and type "disks" or you can open a terminal and use gparted instead.
  • Create a 200Mb fat32 partition and label it boot. Luckily ubuntu leaves some free space by default at the end to save you having to resize the other data partition.
  • I deleted my other Grub boot partition from the start although i think the next step would have done this for me.
  • Install boot-repair
  • sudo add-apt-repository ppa:yannubuntu/boot-repair
  • sudo apt-get update
  • sudo apt-get install -y boot-repair && boot-repair
  • Click advanced and check the new fat32 partition is showing "Separate EFI boot" under grub location.
  • Click apply and follow the steps.
  • One guide also said mount the data partition from disks and check the /etc/fstab to see if it has a different mount point for /boot but i didnt
  • Shutdown the VM and delete the cdrom from devices
  • Start the VM and check the nic has an IP. I had to edit my netplan config as the adaptor had changed from enpos3 to 4
I wish i had tried this before messing with trying to copy data the hard way. This in the end was a pretty straightforward job.
One last niggle to tidy is that apt upgrade is complaining about grub as its now changed to uefi. I guess i just have to remove it.
Searching for GRUB installation directory ... found: /boot/grub
Searching for default file ... found: /boot/grub/default
Testing for an existing GRUB menu.lst file ...
Could not find /boot/grub/menu.lst file. Would you like /boot/grub/menu.lst generated for you? (y/N) /usr/sbin/update-grub-legacy-ec2: line 1101: read: read error: 0: Bad file descriptor
run-parts: /etc/kernel/postrm.d/x-grub-legacy-ec2 exited with return code 1
dpkg: error processing package linux-image-4.15.0-76-generic (--remove):
installed linux-image-4.15.0-76-generic package post-removal script subprocess returned error exit status 1
Removing linux-modules-4.15.0-76-generic (4.15.0-76.86) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Reference: Ubuntu UEFI
bignellrp
It seems i forgot a step. If boot-repair says about installing grub but not about efi on a separate partition then you need to reopen disks and make sure the partition type is EFI boot. I also had to open gparted first as it didnt let me create a new partition until gparted had applied a "fix".
bignellrp
Found a fix for the broken grub:
sudo touch /boot/grub/menu.lst
sudo update-grub2
ete
hey all
not sure this thread is still alive, but i need some help too plz with this topic ::smile:
when i run the DD command (in FreeNAS-11.3-U4), it creates a new file with the name of the zvol i mentioned in the command, but it does not actually deploying the image to the zvol i had created.
i can run the command even without creating a zvol in the GUI beforehand, and it will still create a file with the name i specified in the DD command, at the pool/dataset/volume i specified.
any ideas?
Patrick M. Hausen
Please give us the complete command you are trying.
ete
hey!
thank you for the quick reply
thats the command:
‘dd if=/mnt/RaidZ2/DataSet_I/hassos.img of=/mnt/CrucialVM/CrucialVM/hassOs’
all pics in same frame below
a pic from the gui, as to where i keep my zvols of vms
SSH image after the command finishes:
and the file that was created on that dataset - just a little less than 6.5 GB
as i said - it create this file regardless if there is a zvol with this name or not
how abnormal is this??? should i call mulder and scully, or ghostbusters??
Patrick M. Hausen
The destination is plain wrong. See:
root@freenas[~]# zfs create -V 1G hdd/testvol
root@freenas[~]# dd if=/dev/zero of=/dev/zvol/hdd/testvol bs=1m
dd: /dev/zvol/hdd/testvol: end of device
1025+0 records in
1024+0 records out
1073741824 bytes transferred in 0.765429 secs (1402796906 bytes/sec)
root@freenas[~]# zfs destroy hdd/testvol
A zvol is a block device, not a file.
ete
hey Patrick
thank you for taking the time to help, i appreciate it.
i think i understood what you said, but not sure what to do to fix it.
should i create a zvol with a line command, and not in the gui - was that my problem?
and if so, what sould be the command for a proper creation?
zfs create -V 32G /mnt/CrucialVM/CrucialVM/hassOs
will that do the trick of rectifying it?
Patrick M. Hausen
If your pool is named "CrucialVM" the command is:
zfs create -V 32G CrucialVM/hassOs
without the "/mnt". But you can use the GUI, no problem with that.
Your mistake is that you try to use something like /mnt/CrucialVM/hassOs in your dd command.
Of course this creates a file, because that is a file path. You need to use a device for the "of=" part of dd.
In your case above the device is /dev/zvol/CrucialVM/hassOs like in my example.
ete
gotcha! thanks
or at least got right the part of the destination being all wrong
now, after pointing in the right direction - /dev/zvol/CrucialVM/CrucialVM/HAssOs (where i have already created the zvol)
i get an error of:
dd: /dev/zvol/CrucialVM/CrucialVM/HAssOs: Operation not supported
after running this command:
dd if=/mnt/RaidZ2/DataSet_I/hassos.img of=/dev/zvol/CrucialVM/CrucialVM/HAssOs
more thoughts?
Patrick M. Hausen
Does /dev/zvol/CrucialVM/CrucialVM/HAssOs exist? Check with ls. Apart from that no idea - works here ;)
Edit: one more idea, please post the output of
zfs get volmode CrucialVM/CrucialVM/HAssOs
ete
it appears on 'LS' command, so my guess would be - yes
ill keep digging
thank you so much for your help so far.
was worth it just for that zvol location lesson
so i appreciate it a lot
cheers
if anything comes to mind... just let me know
