Controller question
Hello, I'm actually running Truenas scale on HPE DL380 server.
I have a spare P840 controller, and a lsi 9400 16i.
I also have a HPE D3600 DAS enclosure.
Questions are:
Do P840 controller is good if switched to HBE mode or better use lsi 9400 (I like the P840 because i've got all enclosure's led working and aren't with 9400 16i)
Which controller do you suggest I use to connect DL380 to D3600 enclosure (do lsi 9400 16e will be compatible) ?
Thanks for helping
