Conflict with acomba PME
Darkskills
Hi!
First of all im not that good in english so excuse me...
So I have multiple TrueNAS server at home and it's fire!! I like it so much.
With that in mind I installed a NAS at my job and find out that our Acomba server isn't working anymore.
I did not modify port or anyting on the router. And the moment I stop the truenas server Acomba come's back.
I don't know if it's related or not but it seems like it. Acomba is working with a Windows Share by Windows Sever 2019.
Note : I did not install that server so I don't know wich port it is using...
Do you have any advice?
Thanks!
Patrick M. Hausen
IP address conflict?
Darkskills
Also I have to mention that the Windows Share for Acomba is still accessible and Acomba is "working" it's only when I try to acces the inventory menu when I create a new command.
Samuel Tai
Without more details of your existing Windows environment at the office, we don't have enough information to help.
Just a wild guess, this sounds like NetBIOS browsing may be a factor. I suspect when you installed TrueNAS, it became the local master browser and pre-empted the existing Windows server.
Are you using legacy NetBIOS or SMB1/WINS in this environment? Or have you transitioned to modern WS-Discovery?
Darkskills
I will get more information very soon. I found a procedure to fix that issue if it's the case.
Thanks a lot!
