Compression despite deactivated compression level
Skywalker
Hi guys,
I have a question about compression of files in TrueNAS. I have created different datasets with different compression levels. On one dataset I deliberately disabled compression and still the files were reduced by about 5% by ZFS i.e. compressed. Does ZFS still do an internal minimal file compression despite disabled compression?
many thanks
Are you talking about files that were already there when you turned off compression? (those will remain compressed).
Skywalker
No, in the first step I created the dataset, then deactivated the compression and only then copied the file to the dataset
And how exactly are you determining that the compression is happening?
I don't think that's a good way to compare... are you even sure you're measuring MiB to MiB (not MB)?
In any case, you're talking about 2 different filesystems and how they report filesizes... won't necessarily be the same for the same file(s) due to record/block sizes and other things like file table allocation and padding.
Skywalker
I must admit that I was a bit confused by the information within the system. Are we talking about mebibytes or megabytes in the system information?
On the website: https://www.ixsystems.com/documentation/truenas/11.3-U3.2/tn_intro.html
under point 1.3.7 it says "like M or MiB for megabytes or G or GiB for gigabytes".
also in my book FreeBSD Mastery: ZFS the author always talks about megabyte and never about mebibyte when evaluating with commands (in the display it says e.g. 2M and he says 2 megabyte)
what exactly is correct now?
MiB is mebibytes
MB or M is Megabytes... same for GiB and GB/G
Whattteva
so what exactly is then displayed in the shell if the specification is M or KB? is this then also actually MiB and KiB?
What does the web UI say under Storage -> Pools? It has a Compression Ratio field for every dataset. Is it a number above 1.0? Alternatively, you could also do zfs list -ro name,ratio <dataset_name>. That will probably be a more authoritative source than the du command, which was never built with ZFS in mind.
You can also see that with zfs list -o name,compressratio
Skywalker
The ratio always says 1.0
And the size with du is 770M
but i am still confused if the shell says M for MB or M for MiB
The GUI says 770,77 MiB
It makes a huge difference when I compare those facts on bigger files :-(
Whattteva
The general rule is, OS's generally always use MiB, while hardware manufacturers (HDD) use MB. Your ratio says 1.0, which means no compression is currently taking place.
