I upgraded from Bluefin to Cobia a while ago and there was a bug report about LACP failing to work after the update. I see that there is some patch notes about it getting fixed a while ago, but I still cannot get it to work. I even get the same error as before.
I'm using a Ryzen 5 5600X CPU with 8 20TB drives and 2 250GB SSD cache drives.
The network card is a dual 10G and I'm trying to set it back up to where it was before.
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1900, in _execute_context
self.dialect.do_execute(
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/default.py", line 736, in do_execute
cursor.execute(statement, parameters)
sqlite3.IntegrityError: UNIQUE constraint failed: network_lagginterfacemembers.lagg_physnic
The above exception was the direct cause of the following exception:
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 201, in call_method
result = await self.middleware._call(message['method'], serviceobj, methodobj, params, app=self)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1342, in _call
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 169, in create
return await self.middleware._call(
File "/usr/lib/python3/dist-packages/middlewared/service/crud_service.py", line 194, in nf
rv = await func(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 44, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema/processor.py", line 177, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/network.py", line 806, in do_create
lagports_ids += await self.__set_lag_ports(lag_id, data['lag_ports'])
File "/usr/lib/python3/dist-packages/middlewared/plugins/network.py", line 1153, in __set_lag_ports
await self.middleware.call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1399, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/write.py", line 62, in insert
result = await self.middleware.call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1353, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1251, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/datastore/connection.py", line 106, in execute_write
result = self.connection.execute(sql, binds)
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1365, in execute
return self._exec_driver_sql(
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1669, in _exec_driver_sql
ret = self._execute_context(
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 1943, in _execute_context
self._handle_dbapi_exception(
File "/usr/lib/python3/dist-packages/sqlalchemy/engine/base.py", line 2124, in _handle_dbapi_exception
util.raise_(
File "/usr/lib/python3/dist-packages/sqlalchemy/util/compat.py", line 211, in raise_
raise exception
sqlalchemy.exc.IntegrityError: (sqlite3.IntegrityError) UNIQUE constraint failed: network_lagginterfacemembers.lagg_physnic
[SQL: INSERT INTO network_lagginterfacemembers (lagg_ordernum, lagg_physnic, lagg_interfacegroup_id) VALUES (?, ?, ?)]
[parameters: (0, 'enp1s0f0', 15)]
(Background on this error at: https://sqlalche.me/e/14/gkpj)
util.raise_(
raise exception
