cloudflare tunnel + traefik internal/external network access
nikkon
Hi folks,
I installed cloudflare tunnel and set up for a few of my running apps. I as well have traefik installed and seems to work just fine.
For all apps I needed to use a fqdn instead of the truenas ip and port and i wanted a certificate.
So I created the the apps and checked the ingress option as defined bellow:
Once this was done, I log into cloudflare, defined the tunnel and made sure it works: Access -> zero trust -> Tunnels.
Truenas tunnel is active. Inside the tunnel Instead of defining a Willard I defined each hosts individually like:
and
Now all works great. from internal works. I can access the plex server pretty nicely.
the problem is that from outside the network, everyone will be able to access the same :) and i don't want it.
So I did is to define a self hostef application in Cloudflare: Access -> Application -> SelfHosted and added my email address as log in mechanism + the code cloudflare will generate for you and send it to your inbox:
All works great but one thing: once I activate the email authentication it applies to requests from internal LAN and outside LAN.
I need to keep the email authentication for requests coming from outside my LAN but remove it for internal use.
Any idea how I can do this?
Thanks in advance
