I setup the server and everything was working great.
We had a power outage and when the system came back up the CIFS shares werent working.
When I try to start the CIFS service it says the service cannot be started.
I have searched how to troubleshoot and ran testparm. Here is the output:
Load smb config files from /usr/local/etc/smb4.conf
max_open_files: increasing sysctl_max (11095) to minimum Windows limit (16384)
rlimit_max: increasing rlimit_max (11095) to minimum Windows limit (16384)
Processing section "[Data]"
Loaded services file OK.
WARNING: lock directory /var/db/samba4 should have permissions 0755 for browsing
to work
WARNING: state directory /var/db/samba4 should have permissions 0755 for browsin
g to work
WARNING: cache directory /var/db/samba4 should have permissions 0755 for browsin
g to work
Server role: ROLE_STANDALONE
Press enter to see a dump of your service definitions
I dont know what these things mean or where to go from here. Can anyone help?
Here is /usr/local/etc/smb4.conf
[global]
server max protocol = SMB2
encrypt passwords = yes
dns proxy = no
strict locking = no
oplocks = yes
deadtime = 15
max log size = 51200
max open files = 11070
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
getwd cache = yes
guest account = nobody
map to guest = Bad User
obey pam restrictions = Yes
directory name cache size = 0
kernel change notify = no
ea support = yes
store dos attributes = yes
hostname lookups = yes
time server = yes
acl allow execute always = true
local master = yes
idmap config *:backend = tdb
idmap config *:range = 90000000-100000000
server role = standalone
netbios name = HIVE
workgroup = WORKGROUP
security = user
pid directory = /var/run/samba
smb passwd file = /var/etc/private/smbpasswd
private dir = /var/etc/private
create mask = 0666
directory mask = 0777
client ntlmv2 auth = yes
dos charset = CP437
unix charset = UTF-8
log level = 1
[Data]
path = /mnt/vol0
printable = no
veto files = /.snap/.windows/.zfs/
writeable = yes
browseable = yes
recycle:repository = .recycle/%U
recycle:keeptree = yes
recycle:versions = yes
recycle:touch = yes
recycle:directory_mode = 0777
recycle:subdir_mode = 0700
vfs objects = zfsacl streams_xattr aio_pthread
hide dot files = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = yes
zfsacl:acesort = dontcare
Can anyone assist? I cannot access my files!
to work
g to work
g to work
[global]
dns proxy = no
strict locking = no
oplocks = yes
deadtime = 15
load printers = no
printing = bsd
getwd cache = yes
ea support = yes
time server = yes
local master = yes
netbios name = HIVE
security = user
create mask = 0666
dos charset = CP437
log level = 1
[Data]
path = /mnt/vol0
printable = no
writeable = yes
browseable = yes
recycle:touch = yes
guest ok = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = yes
