herewegoagain
- Aug 29, 2023
So i’m having some issues with my NAS and rebuilding an array (TruNAS) let me start at the beginning.
Setup 8x10TB (half Exos half WD RED PRO) in RAID Z2
SAS2008 card (Now SAS3008 in IT mode FW 16.0.12.0)
Ryzen 5 + Server Mobo
128 GB ECC DDR4 RAM
I do have all this data backed up but i’m concerned that ZFS is unable to repair this and this is a larger issue with hardware or a bug and is makeing me question my choices…
What do?
also pulled this from the ZFS log all of the checksum errors are the same with the “BAD_SET_HISTOGRAM= 0x0 0x0……” which is odd
128 GB ECC DDR4 RAM
- I started seeing Checksum errors on one of my drives… tried some scrubs and clears and the numbers started jumping around for the number of errors (61,133,271,45,) at this point i decided to replace the drive
- I replaced the drive but the new replacement drive is showing the same Checksum errors and Scrubs are not fixing them…. still jumping around after clears and scrubs (150,61,23)…. tried swapping SAS ports…… issue follows drive
- Figured new drive was damaged during shipping, got second replacement WD RED PRO and resilvered the array again…… Checksum errors return and drive errors out ….scrubs don’t fix it and checksum errors continue after clears and repeated scrubs
- Figured it was a SAS card issue… replaced with SAS3008 card + new wiring…. wiped drive and did rebuild and still seeing Checksum errors tried scrubs and clearing again but numbers jump around after each scrub (1,61,32)
- Upgraded SAS HBA firmware based on recommended firmware…. checksum issue still occurs
- Put new drive on Mobo SATA port to see if there was some R/W issue with the HBA …. checksum issue still occurs
- removed Cache Drives and resilvered + Scrub ….issue still occurs
- pulled both new drives in to a separate system checked for errors or SMART issues and wiped with all zeros put back in TrueNAS resilvered + Scrub….. checksum issue still occurs
What do?
Aug 27 2023 17:15:56.924972503 ereport.fs.zfs.checksum
class = "ereport.fs.zfs.checksum"
ena = 0x4ebc9aad14000801
detector = (embedded nvlist)
version = 0x0
scheme = "zfs"
pool = 0x70469b758805927c
vdev = 0x9953bc42d191f128
(end detector)
pool = "storage_pool"
pool_guid = 0x70469b758805927c
pool_state = 0x0
pool_context = 0x0
pool_failmode = "continue"
vdev_guid = 0x9953bc42d191f128
vdev_type = "disk"
vdev_path = "/dev/disk/by-partuuid/835c0980-932c-4093-95c9-37e1d0fb4478"
vdev_ashift = 0x9
vdev_complete_ts = 0x54ebc9a12ba7
vdev_delta_ts = 0xf973
vdev_read_errors = 0x0
vdev_write_errors = 0x0
vdev_cksum_errors = 0x1
vdev_delays = 0x0
parent_guid = 0x22ce662618e98491
parent_type = "raidz"
vdev_spare_paths =
vdev_spare_guids =
zio_err = 0x0
zio_flags = 0x1008b0
zio_stage = 0x200000
zio_pipeline = 0x1f00000
zio_delay = 0x0
zio_timestamp = 0x0
zio_delta = 0x0
zio_priority = 0x4
zio_offset = 0x27906359000
zio_size = 0x1000
zio_objset = 0x0
zio_object = 0x0
zio_level = 0x0
zio_blkid = 0x0
bad_ranges = 0x0 0x1d0 0x1e8 0x768 0x780 0x7d8 0x7e8 0x800
bad_ranges_min_gap = 0x8
bad_range_sets = 0x0 0x0 0x0 0x0
bad_range_clears = 0xe67 0x2bf4 0x28b 0x85
bad_set_histogram = 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0 0x0
bad_cleared_histogram = 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf5 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf5 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf6 0xf5 0xf5 0xf5 0xf5 0xf5 0xf5 0xf5 0xf5 0xf5 0xf5 0xf5 0xf6 0xf6 0xf6 0xf6 0xf6 0xf5 0xf5 0xf5 0xf5 0xf5 0xf5 0xf5 0xf5
time = 0x64ebbd0c 0x3721f5d7
eid = 0xce
Aug 27 2023 17:38:48.402709403 ereport.fs.zfs.checksum
ena = 0x62b1b18cc4000001
version = 0x0
scheme = "zfs"
(end detector)
pool_state = 0x0
pool_context = 0x0
vdev_type = "disk"
vdev_ashift = 0x9
vdev_complete_ts = 0x562b1ae18c7a
vdev_delta_ts = 0x22f8e12
vdev_cksum_errors = 0x2
vdev_delays = 0x0
vdev_spare_paths =
vdev_spare_guids =
zio_err = 0x0
zio_flags = 0x100880
zio_delay = 0x0
zio_timestamp = 0x0
zio_delta = 0x0
zio_priority = 0x0
zio_offset = 0x27a4e4bb000
zio_size = 0x1000
zio_objset = 0x71
zio_object = 0x1118
zio_level = 0x0
zio_blkid = 0x0
bad_ranges = 0x0 0x518 0x530 0x800
bad_range_clears = 0x2891 0x167c
bad_cleared_histogram = 0xfd 0xfd 0xfd 0xfd 0xfc 0xfc 0xfc 0xfc 0xfd 0xfd 0xfd 0xfd 0xfd 0xfd 0xfd 0xfd 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfd 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc 0xfc
time = 0x64ebc268 0x1800db9b
eid = 0xcf
