xxx@xxx:~$ ssh NAS@192.168.x.xx -p xxxx
NAS@192.168.1.22's password:
Last login: Wed May 6 09:08:45 2020 from 192.168.x.xx
FreeBSD 9.3-RELEASE-p31 (FREENAS.amd64) #0 r288272+e7e804d: Mon May 16 21:29:59 PDT 2016
FreeNAS (c) 2009-2015, The FreeNAS Development Team
All rights reserved.
FreeNAS is released under the modified BSD license.
For more information, documentation, help or support, go here:
http://freenas.org
Welcome to FreeNAS
root@freenas:~ # smartctl -a /dev/ada1
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p31 amd64] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke,
www.smartmontools.org
Model Family: Western Digital Scorpio Blue Serial ATA
Device Model: WDC WD5000BEVT-11ZAT0
Serial Number: WD-WXNY08NV1896
LU WWN Device Id: 5 0014ee 2025dce0f
Firmware Version: 01.01A01
User Capacity: 500,107,862,016 bytes [500 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5400 rpm
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Sun Oct 25 21:41:14 2020 CET
SMART support is: Enabled
General SMART Values:
was never started.
been run.
data collection: (13200) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 154) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303f) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 2792
3 Spin_Up_Time 0x0027 157 147 021 Pre-fail Always - 3150
4 Start_Stop_Count 0x0032 090 090 000 Old_age Always - 10490
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 050 050 000 Old_age Always - 37017
10 Spin_Retry_Count 0x0033 100 100 051 Pre-fail Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 098 098 000 Old_age Always - 2107
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 728
193 Load_Cycle_Count 0x0032 001 001 000 Old_age Always - 1443515
194 Temperature_Celsius 0x0022 117 098 000 Old_age Always - 30
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 3
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 3729
200 Multi_Zone_Error_Rate 0x0009 200 200 051 Pre-fail Offline - 53
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 36383 -
# 2 Extended offline Completed without error 00% 36279 -
# 3 Short offline Completed without error 00% 36240 -
# 4 Short offline Completed without error 00% 36096 -
# 5 Short offline Completed without error 00% 35952 -
# 6 Short offline Completed without error 00% 35809 -
# 7 Short offline Completed without error 00% 35641 -
# 8 Short offline Completed without error 00% 35498 -
# 9 Short offline Completed without error 00% 35443 -
#10 Short offline Completed without error 00% 35275 -
#11 Short offline Completed without error 00% 35132 -
#12 Short offline Completed without error 00% 34988 -
#13 Short offline Completed without error 00% 34844 -
#14 Short offline Completed without error 00% 34557 -
#15 Short offline Completed without error 00% 34414 -
#16 Short offline Completed without error 00% 34270 -
#17 Short offline Completed without error 00% 34127 -
#18 Short offline Completed without error 00% 33983 -
#19 Short offline Completed without error 00% 33815 -
#20 Extended offline Completed without error 00% 33711 -
#21 Short offline Completed without error 00% 33672 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
root@freenas:~ #
