Checking new HDD's in RAID
Looks like only the conveyance test is not supported on my jbod. Just finished running the short test on all the drives and those worked fine.
Can you read the S.M.A.R.T. data? Do long tests work?
Are the drives involved the WD Reds or the Hitachis? If it's the Hitachis, they may not have a conveyance test for some weird reason, which would mean the rest of the setup is working normally.
Hugo Ochoa
Yes, I can read the reports for all the drives. The short and long tests both worked fine. Faster on the Hitachis than WD drives. Conveyance tests worked fine on the WD drives but apperantly are not supported on my Hitachi drives. I'm currently running some badblocks test on all the drives.
Sent from my HTC One_M8 using Tapatalk
trionic
Just a note that the System Rescue CD Linux distro contains many useful data recovery and testing utilities, including memtest+, dd, badblocks and iozone. The distro can be booted from CD/DVD/USB.
In addition, it looks like FreeDOS and other boot floppy images can be started directly from SysRescue's boot menu, providing an environment to execute wdidle3.exe (yet to be proven but I'll update this post when I know for sure).
trionic
Thank you for the advice. RMA created. Do WD ship new or refurbished replacement drives?
The replacement drive was "recertified". Crap considering the defective drive was new. The replacement looks like a Black drive. Sticker says "NASWare".
Not feeling too confident about a using recertified this drive in a ZFS VDEV. Thoughts?
I have mixed feelings about recertified drives. Some are just idiots that RMA stuff and have no idea that the drive is actually good. The *real* problem though is this... is the chances of a recertified drive failing "prematurely" the same as a "new" drive failing "prematurely"?
You buy a drive, if it's got no sticker could you really tell the difference and predict when it would fail? If you had a new and recertified drive can you run some kind of test and prove that a recertified drive isn't as good as new? If so, you just hit jackpot and many IT geeks everywhere will thank you. But if it stores your data right now, passes all SMART monitoring, SMART tests, bad blocks tests, etc does it really matter?
michaelkoehler
A second recommended way to check on drive performance and do some stress testing is to do a "dd" read of the each of the drives.
From the Shell you can run the following command - note this is to test 6 drives, adjust it if you have fewer or more drives.
# for i in 0 1 2 3 4 5; do (press return it will then start a new line where you continue)
> dd if=/dev/ada${i} of=/dev/null bs=1048576 & (press return again)
> done (after pressing return it will actually run the above commands)
this will take a long time (hundreds of minutes) and as long as you keep the Shell open, when it does complete it will report how long it took for each of the drives, if one is much longer than the others, it could have a performance issue (even if it passes SMART) (when I did this test on 6 drives, I left it overnight and saw the next morning they were all within 10% of each other)
Great post, Brian.
When I run this, I get an immediate response, though. Am I not waiting long enough, or am I doing something wrong? Is this what the results should look like?
[root@freenas ~]# for i in 0 1 2 3 4 5; do
> done
[1] 4925
[2] 4926
[3] 4927
[4] 4928
[5] 4929
[6] 4930
[root@freenas ~]#
scurrier
Great post, Brian.
> done
[1] 4925
[2] 4926
[3] 4927
[4] 4928
[5] 4929
[6] 4930
[root@freenas ~]#
Maybe those are the process id's? Did you check to see if they correspond to what's running in "top"?
Fraoch
(deleted)
pjc
Then you run iozone in a seek-heavy manner. Then you keep that running a few weeks (no, seriously, weeks is on the short end).
What do you recommend for that? Random read/write? How do you make it run for weeks?
jgreco
Resident Grinch
Actually several discussions here have convinced me to revisit an old tool ... I may have something more specific for you to run soon.
Dennis.kulmosen
FN comes with a nice tool called badblocks. In write mode you need to do it on each raw device. Badblocks writes a pattern to the device and reads it while comparing it to the pattern. Its slow, but its a complete surface scan plus stress test of the drive. :smile:
So what are you doing with my mom now?
pjc
Let me know...I'll be interested.
This may be a silly question, but will seek-heavy usage also increase the drive temperature, or does read/write tend to increase it the most? I may also use this opportunity to do a thermal test on my fan configuration...
Random accesses will cause the greatest increase, from an intuitive point of view.
pjc
That's what I would have thought (power required to move the head, etc.), but I wasn't sure, since most data sheets just list power consumption for read/write vs. idle.
Now I'm looking forward to jgreco's seek-heavy stress test even more...
Fraoch
Just wanted to say this thread is helping out tremendously for testing.
A quick note: turn off snapshots during those intense iozone tests! You may run out of space if you have aggressive snapshot settings where the snapshot will try to capture those 100 GB+ files you create in iozone.
jgreco
Resident Grinch
HAHAHAHAHAHHAHAHAHAHAHAHAHHAHAHAH! That is AWESOME!
Fraoch
Yeah, I wondered what was going on there...the snapshots don't care and will happily and dutifully create snapshots for you as they're supposed to. All the while your total capacity is dropping even after iozone is finished and the large files are deleted.:eek:
Mlovelace
  • IMB_M1015.PDF
