Hello. There is new boolean configuration option in samba 4.1.0 named "acl allow execute always"
After update to Samba 4 you cannot execute ".exe" files right from share without this option, like you did that on Samba 3.6. Adding this option make files execute as needed.
Adding "acl allow execute always = true" to "auxiliary parameters" in CIFS config does the trick. But it would be much better if such button appear in CIFS parameters.
Thanks
Thanks
