Dear all,
I would like to change the case of my TrueNAS build (MB, RAM, HDD stay the same).
I searched the forum and saw this discussion, where it was recommended to check that gptid is used for naming instead of da0/ada0/
The GUI suggest that in my case it is the latter:
Could someone please confirm that this is indeed needed as I will likely not plug in drives in the same order in the new case.
If so, how do I change this in my pool?
p.s. I am running TrueNAS-13.0-U6.1
Thank you for the help,
Denis.
Denis.
