Philosophical
- Oct 3, 2020
I currently have a pair of WD Red 2tb drives in a mirror pool running freenas 11.2U2 I want to remove the second drive as a mirror and instead stripe both drives to be able to access 4tb.
do I just detach the second drive from the command line and then add it to the first drive as a striped pool or do I export the pool and only import a single drive? im assuming this wont work as it will just be looking for another drive to re-create the mirror.
I did some searching and have seen lots of posts about adding drives or replacing drives but not much about changing from a mirror to a stripe. I assume that since both drives have the same data on them that you should be able to do this without loosing anything?
