Change TrueNAS IP, battling with jail network
georgelza
hmmm, so that I can clean up, how do I tag text as code...
G
OK, so where are we now? is vnet:1 for the jail?
Is it starting without error yet?
georgelza
you say vnet1 ...not vnet0 as defined, and oh btw, i did not pick the name. was created when i created the test jail.
georgelza
No.
From your extract of the jail properties:
vnet:0
vnet0_mac:06aedba63966 06aedba63967
vnet0_mtu:auto
How I think it should be (would match with one of my jails which uses vnet0):
vnet:1
vnet0_mtu:auto
vnet:1 as far as I can see refers to vnet being enabled vs not enabled if it's 0.
georgelza
ahh ok, so how we enable the vnet then ?
G
iocage set vnet=1 Unify-Controller-6
georgelza
bingo
iocage set vnet=on <jail name>
jail started
One other difference I see between your jail and one I have that uses a static address is:
ip4_saddrsel:1 (yours is set to 0)
OK, so that's great that it's working... you can probably ignore that one.
georgelza
AWESOME, thanks.
Now to remember my admin password, as it's not associating the new IP with old IP with the password.
G
georgelza
password sorted. thank you Safari.
G
georgelza
THANKS for sitting with me yesterday to sort this out, really appreciated, restore faith in online support/communities. not been having the most "success" of late.
G
