I need some help.
I have FreeNAS-11.2-U8 running behind a firewall and proxy server.
The proxy gets all the certs via cerbot and then scp, then to the other servers.
My question is how can I import the certs that are generated/opbtained by the proxy and copied into the freenas server?
There are 4 files:
cert.pem
chain.pem
fullchain.pem
privkey.pem
Not sure how to import them into freenas.
Files are currently just being copied to the /root/ssl folder on the reenas server.
If there is a script that can import them to automate the process that would be creat.
Any help is appriciated.
Thank you in advance
George
I need some help.
There are 4 files:
cert.pem
chain.pem
fullchain.pem
privkey.pem
George
