I am currently testing out the parts in my sig. I have 6x 6tb reds on order. My plan is to have two different pools:
6x 6TB = pool #1
8x 2TB = pool #2 (the 2TB's are leftovers from other builds).
With the joy of jails & VM's I can cut out the number of PC's running full time. If I can figure out how to get a PCIx card resources sent to a VM I can get rid of three servers which would be good.
Way back in 2006 I bought this (LIAN LI PC-201B Black Aluminum ATX Full Tower Computer Case)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112109
It should hold all the drives without an issue (in theory) but I may be better off with a different case solution. Any advice or suggestions would be great.
Thanks,
Rich
6x 6TB = pool #1
Thanks,
Rich
