Can't update the system
Letigid
Hello, in new TrueNAS system.
So, i have tried to update the system but it doesn't exist the update buttom.
Only existe the option for update manually, and it doesn't let me update too. Why? because it says this error:
  File "/usr/local/lib/freenasOS/Update.py", line 1258, in ExtractFrozenUpdate
    with tarfile.open(tarball) as tf:
  File "/usr/local/lib/python3.9/tarfile.py", line 1616, in open
    raise ReadError("file could not be opened successfully")
tarfile.ReadError: file could not be opened successfully
  File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 367, in run
    await self.future
  File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 403, in __run_body
  File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 975, in nf
  File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/update.py", line 389, in file
    await self.middleware.call('update.install_manual_impl', job, destfile, dest_extracted)
  File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1256, in call
    return await self._call(
  File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1224, in _call
  File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1128, in run_in_executor
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
  File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/update_/install_freebsd.py", line 56, in install_manual_impl
    Update.ExtractFrozenUpdate(path, dest_extracted, verbose=True)
  File "/usr/local/lib/freenasOS/Update.py", line 1278, in ExtractFrozenUpdate
    raise Exceptions.UpdateBadFrozenFile("Bad tar file {0}".format(tarball))
NameError: name 'Exceptions' is not defined
thank you.
save your config
download the ISO of the version you want, put it on some kind of boot media and boot to it, then install over the top of your current install.
If it picks up the current install, you may just be fine with no further action, otherwise, restore your config at the end.
Letigid
save your config
Ty i gonna try it.
but why i doenst still having the buttons that are not on the update panel, it could be a bad installation in first?
That's the assumption... something not right with one or more of the files in the OS.
Letigid
save your config
I just reinstall the system an all work correctly, it could be for two reasons, first installation was in a virtual machine with limited storage or a bad installation process. Second reason could be for the second installation i do in a real machine i have and it work correctly in first look
jgreco
Resident Grinch
See the notes in
Under-resourcing your virtualized NAS is a good way to cause things not to work properly, and modern TrueNAS Core has a 16GB minimum memory requirement, and had 8GB before that. If you were trying to run with less than 8GB RAM, for example, the modern middleware and ZFS are known to be problematic because they are, well, fat.
Letigid
See the notes in
for the test the 8gb go well, but yeah, now i installed it in better real machine and works better than the VM
