Can't start Plexmediaserver
avalon60
I have just been following this video on how to get plexmedia working in FreeNAS
https://plus.google.com/u/0/110373675402281849911/posts/jGKciPXroFn
At 7.30 mins, it says to start the plexmediaserver with the button on the right. When I try to move the button to the ON position, I get an error, namely 'some error has occured', and the service does not turn on. Also the video show the plexmediaserver under the Plugins menu on the left, but I don't because it won't start.
I am using FreeNAS 9.2.1.6 x64bit
avalon60
joeschmuck
Old Man
The plugin should have worked fine, not sure what happened but would need more details from the log file. But that is gone now and you do have Plex installed in a different method.
To be honest, it doesn't matter which way you do it, either is fine.
