I got this error today
I'm running a
phenom II x4 955
8 gb ecc ram(I know I need more)
250 GB main drive
It's been working perfect for 3 weeks
			CRITICAL
Failed to check for alert HasUpdate: Traceback (most recent call last): File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/alert.py", line 740, in __run_source alerts = (await alert_source.check()) or [] File "/usr/local/lib/python3.9/site-packages/middlewared/alert/base.py", line 212, in check return await self.middleware.run_in_thread(self.check_sync) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1155, in run_in_thread return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1152, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run result = self.fn(*self.args, **self.kwargs) File "/usr/local/lib/python3.9/site-packages/middlewared/alert/source/update.py", line 67, in check_sync path = self.middleware.call_sync("update.get_update_location") File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1295, in call_sync return self.run_coroutine(methodobj(*prepared_call.args)) File "/usr/local/lib/python3.9/site-packages/middlewared/main.py", line 1335, in run_coroutine return fut.result() File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 439, in result return self.__get_result() File "/usr/local/lib/python3.9/concurrent/futures/_base.py", line 391, in __get_result raise self._exception File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/update.py", line 412, in get_update_location os.chmod(path, 0o755) OSError: [Errno 28] No space left on device: '/var/db/system/update'
I'm running a
phenom II x4 955
250 GB main drive
