Fish
- Jun 4, 2015
Hi all,
I'm decommissioning a pool and selling the drives off. In the CLI, I did a
I figured the pool would disappear after I removed the drives, so I powered down the NAS, removed them, and booted back up. The purple pool is still listed in the UI now as "LOCKED" - it was geli-encrypted. The same error as above shows when I try to export/disconnect from the UI.
Any ideas?
zpool destroy purple which succeeded - the pool was no longer listed in zpool list. In the TrueNAS UI, I then went to export the pool but after I click export and check "Confirm Export/Disconnect" I get this error:Code:
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 355, in run
await self.future
File "/usr/local/lib/python3.9/site-packages/middlewared/job.py", line 391, in __run_body
File "/usr/local/lib/python3.9/site-packages/middlewared/schema.py", line 981, in nf
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 1608, in export
disks = [i async for i in await self.middleware.call('pool.get_disks', oid)]
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 1608, in <listcomp>
File "/usr/local/lib/python3.9/site-packages/middlewared/plugins/pool.py", line 1059, in get_disks
disk_path = os.path.join('/dev', d['devname'])
KeyError: 'devname'I figured the pool would disappear after I removed the drives, so I powered down the NAS, removed them, and booted back up. The purple pool is still listed in the UI now as "LOCKED" - it was geli-encrypted. The same error as above shows when I try to export/disconnect from the UI.
Any ideas?
