Can't reach Jails from outside using OpenWRT
gaszto
Hi All,
I using TP-Link router with OpenWRT, and I set port forwarding.
- my router adress 192.168.0.1
- my FreeNAS address is 192.168.0.100
- my jails starting 192.168.0.2 to 192.168.0.11
I set port forwarding for 192.168.0.100:22, and I can reach it perfectly. I tried to reach one of my jail 192.168.0.11:80 and I can't. If I set the port 80 to 192.168.0.100 it works perfectly I can using FreeNAS web GUI. But the jails not.
I've tried to ssh to my router 192.168.0.1 and ping 192.168.0.11 and no answer. If I pinging my FreeNAS 192.168.0.100 from the router it also works perfectly.
Anybody has an idea why I can see my jails?
Originally when I used my router with the original TP-Link firmware the port forwarding worked fine, but the factory firmware had a lot of bugs and the router stopped randomly between 24-48 hrs.
Thanks
Gaszto
gaszto
Sorry,
I solved. I fill out the jails Ipv4 default gateway to my router's address 192.168.0.1, and everything works :) But I'm not sure what is the difference the factory firmware and openwrt port forwarding rule.
Gaszto
