thegardenhermit
- Aug 24, 2022
My home network is set up with a mesh WiFi system, this is not by choice as trying to run Ethernet in my walls was not successful due to the central air system. I've been over all my IP configs for the devices connected to the secondary router and everything matches. I can ping devices between the two routers and virtual machines hosted on the truenas, but not the truenas itself. I have a network bridge configured so that I can set up VMs on the NAS. i've run nmap to sniff out visible IPs on my LAN and not everything will show, even devices that are ping-able. I can ping and access the truenas only if im connected to the switch/router adjacent to the truenas.
default gateway is 192.168.4.1
truenas13 ip is 192.168.5.138/22
vm ip is 192.168.5.125/22
workstation computer 192.168.4.211/22
Let me know if more information is needed, I'm tinkering with this after work.
