Can't mount ISO to VM: Permission denied
anodos
Sambassador
Hello, I found a solution for myself. I needed to include user libvirt-qemu to all of the parent datasets and then it worked!
Yeah, this is a fairly common mistake with those unfamiliar with permissions on Unix (Linux / FreeBSD). Users need execute on all parent path components (directories) in order to access a given path. I added extra validation in our ACL editor for 22.02.2 to walk back each path component and raise a validation error if you try to grant access for a user / group in an ACL for a path to which the user can't chdir.
Rod_
Had the same issue today with the ISO permission and also when i tried to "chmod" with the root user got "Operation not permitted".
I have tired what @anodos said and it worked.
used the GUI, attached screenshot.
In my ACL permission i have "Group - builtin_users" with Full control.
What i did, searched for the "libvirt-qemu" user in users credentials and add this user to "builtin_users" as an "Auxiliary Groups".
Then it worked.
Hope this help
WORKED!
Kasazn
Then it worked.
Hope this help
Thank you for the guide. It worked.
TheRiceKing
I have the same problem updating from TrueNAS Core 12 few days ago. Must be a bug when upgrading. Does anyone having same problem install a fresh copy of TrueNAS Scale then restore, and importing previous ZFS? I initially upload the ISO to my /mnt/NAS/Data1/AppLib/ISO/ubuntu-22.04-desktop-amd64.iso, it was able to upload the file to it, but can't read. Does that mean it uses different account to upload then libvirt-qemu to read the ISO?
I followed the kb gave libvirt-qemu modify/full access without any luck.
I checked /etc/libvirt/qemu.conf #dynamic_ownership = 1 is the default.
I've Strip ACL, and reset ACL
I'm stuck! :(
I can confirm that this was the solution for me too. Thank you.
jayO
Running TrueNAS-SCALE-23.10.2 for the first time and had the same issue. Was able to select the .iso after relaxing the User - libvirt-qemu ACL on the Dataset where the .iso was located from Read -> Read, Write, and Execute.
