Can't join Active Directory,Failed to validate bind credentials: [EFAULT] timed out
anodos
Sambassador
I tried that command and the middleware service never came back up and I couldn't access the server anymore, I had to re-install it.
Yes, that's the reason why I specified backing up the original file. You should also do hotpatching through an SSH session (so that you don't cut your feet out from under yourself).
glossjorge
I did backup the original file, I was doing it via ssh, but when the service did not come back, I lost ssh connection, so I went to the server directly and it did not let me do anything with it.
ram777
Finalized fix is here: https://raw.githubusercontent.com/f...ewared/middlewared/plugins/activedirectory.py
Back up and replace /usr/local/lib/python3.7/site-packages/middlewared/plugins/activedirectory.py with the version linked above, and then restart the FreeNAS middleware. service middlewared onerestart
I replaced activedirectory.py with the last version you give us. I restarted Freenas machine . Connecting to AD still does not work : Failed to validate bind credentials: [EFAULT] timed out
anodos
Sambassador
PM me a copy of /var/log/middlewared.log. validate_credentials() in the updated version doesn't make any socket calls (it just performs a kinit). Sounds like a mis-applied patch.
hemlock
I'm using the LDAP directory service, updated to version 11.3-U1 and also grabed the most recent activedirectory.py file I am getting this error message whenever I try connecting to the ad server.
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/ldap.py", line 621, in port_is_listening
    s.connect((host, port))
socket.timeout: timed out
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/ldap.py", line 586, in do_update
    await self.middleware.call('ldap.ldap_validate', new)
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1127, in call
    app=app, pipes=pipes, job_on_progress_cb=job_on_progress_cb, io_thread=True,
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1077, in _call
    return await methodobj(*args)
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/ldap.py", line 488, in ldap_validate
    await self.middleware.call('ldap.port_is_listening', host, int(port), data['dns_timeout'])
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 1091, in _call
    return await run_method(methodobj, *args)
  File "/usr/local/lib/python3.7/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
    return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
  File "/usr/local/lib/python3.7/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/ldap.py", line 625, in port_is_listening
    raise CallError(e)
middlewared.service_exception.CallError: [EFAULT] timed out
  File "/usr/local/lib/python3.7/site-packages/middlewared/main.py", line 130, in call_method
    io_thread=False)
  File "/usr/local/lib/python3.7/site-packages/middlewared/service.py", line 302, in update
    f'{self._config.namespace}.update', self, self.do_update, [data]
  File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 961, in nf
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/ldap.py", line 588, in do_update
    raise ValidationError('ldap_update', str(e))
middlewared.service_exception.ValidationError: [EFAULT] ldap_update: [EFAULT] timed out
anodos
Sambassador
    raise CallError(e)
    io_thread=False)
LDAP and AD are separate plugins.
hemlock
Gotcha, that makes sense. I should have realized that. However it seems like I'm experiencing the same issues as the people using the Active Directory Plugin. Is there anything obvious that I'm just completely missing when using the LDAP plugin?
hemlock
I reverted to 11.2-U7 boot environment and was able to connect using LDAP @anodos As soon as i switch back to 11.3-U1 boot environment i have the same time out error message now. I've downloaded all the most recent patches.
anodos
Sambassador
If you're getting a socket timeout for the LDAP plugin, you can increase the value of the DNS timeout. It's also used in the socket.connect() call that is returning the error. Maybe bump both timeout values to 30 seconds from 10.
hemlock
Okay tried 30 seconds same time out with socket.connect() returning the error. Tried 60 seconds also, same thing. Do i need to have the hostname have the netbios name in it like this netbios\ad-hostname thats how i currently have it.
uri
@anodos hello! have you any suggestions about losing connection to AD after restart, that I mentioned earlier?
anodos
Sambassador
hemlock
Currently the LDAP plugin just times out even if i set the timeout for ldap and dns to a higher number. If there is something I can do to help troubleshoot this I'm all ears. We are using Azure Active Directory, like I said this all works whenever I revert back to 11.2 however because of various reason I can't stay on that version. The settings I'm using are all identical from 11.2 to 11.3 @anodos
hemlock
Currently the LDAP plugin just times out even if i set the timeout for ldap and dns to a higher number. If there is something I can do to help troubleshoot this I'm all ears. We are using Azure Active Directory, like I said this all works whenever I revert back to 11.2 however because of various reason I can't stay on that version. The settings I'm using are all identical from 11.2 to 11.3 @anodos View attachment 36245
So when I change settings to point at a internal server not using ssl it works just fine.
anodos
Sambassador
As I've already mentioned, this particular forum thread is about issues involving AD. You're using the LDAP plugin. There are several bugfixes related to the LDAP plugin in the 11.3-stable branch on github. https://raw.githubusercontent.com/f...e/src/middlewared/middlewared/plugins/ldap.py. You can try cloning your boot environment, replacing /usr/local/lib/python3.7/site-packages/middlewared/plugins/ldap.py with the version attached, and then issuing "service middlewared onerestart". If your problem persists and you don't see a corresponding bug ticket in our bug tracker, you are welcome to file one there.
uri
