Aberu
- Jan 30, 2015
I know I should have had backups of my configs originally. Few things...
No the volume wasn't encrypted.
I can navigate the volume like it was there in console, but GUI doesn't recognize them at all. Here's a list of commands I ran to get as much info as I thought relevant and could find based on the internet searches I did before I posted here. Here's from the GUI what I see:
As you can see I can navigate to the volume so this would imply that it was automatically imported as per 9.3's wizard at the beginning. Sweet! But wait, I can't see in the GUI so I can't create a CIFS share or do anything with plugins or anything at all! So I decided to check status...
Hrmmm okay everying looks good! Why isn't this working? Maybe it thinks it's imported so it's not?
So clearly Freenas recognizes that it HAS been imported. WTF? So I saw online something about showing glabel status for more info (dunno why) just in case this helps...
They are all the same drive, same size, ordered the same day, etc... But I have 4x3 tb drives... What's going on with this? Why does this show 8 drives in addition to the usb drive I'm using? So I found hopefully another useful way to find specific info just in case it might help whoever wants to help me with this.
So you can see why I'm having trouble here! It looks like everything is fine but it sure isn't showing up in the GUI. I checked the documentation for FreeNAS and I don't see anything in there to address this issue as far as I can tell! Any help is appreciated greatly!
Also if worse comes to worse and I have to format every drive and start from scratch, it's not the end of the world, just want to see if I don't have to spend another month or so downloading everything again!
[root@freenas] /mnt/v1# ls ./ ../ .system/ jails/ media/ owncloud/
[root@freenas] /mnt/v1# zpool status
pool: freenas-boot
state: ONLINE
scan: none requested
NAME STATE READ WRITE CKSUM
freenas-boot ONLINE 0 0 0
da0p2 ONLINE 0 0 0
errors: No known data errors
pool: v1
state: ONLINE
scan: scrub repaired 0 in 30h46m with 0 errors on Fri Jan 2 06:46:13 2015
v1 ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/757db659-4116-11e4-a123-002590d4bdbb ONLINE 0 0 0
gptid/75d77186-4116-11e4-a123-002590d4bdbb ONLINE 0 0 0
gptid/7637a646-4116-11e4-a123-002590d4bdbb ONLINE 0 0 0
gptid/769a5b3b-4116-11e4-a123-002590d4bdbb ONLINE 0 0 0
[root@freenas] /mnt/v1# zpool import v1 cannot import 'v1': a pool with that name is already created/imported, and no additional pools with that name were found
[root@freenas] /mnt/v1# glabel status
Name Status Components
gptid/2a3514cd-a81d-11e4-9e59-002590d4bdbb N/A da0p1
gptid/75725812-4116-11e4-a123-002590d4bdbb N/A ada0p1
gptid/757db659-4116-11e4-a123-002590d4bdbb N/A ada0p2
gptid/75cbb813-4116-11e4-a123-002590d4bdbb N/A ada1p1
gptid/75d77186-4116-11e4-a123-002590d4bdbb N/A ada1p2
gptid/762b42f1-4116-11e4-a123-002590d4bdbb N/A ada2p1
gptid/7637a646-4116-11e4-a123-002590d4bdbb N/A ada2p2
gptid/768edc23-4116-11e4-a123-002590d4bdbb N/A ada3p1
gptid/769a5b3b-4116-11e4-a123-002590d4bdbb N/A ada3p2
[root@freenas] /mnt/v1# gpart list |more Geom name: da0 modified: false state: OK fwheads: 255 fwsectors: 63 last: 31405790 first: 34 entries: 128 scheme: GPT Providers: 1. Name: da0p1 Mediasize: 524288 (512k) Sectorsize: 512 Stripesize: 0 Stripeoffset: 17408 Mode: r0w0e0 rawuuid: 2a3514cd-a81d-11e4-9e59-002590d4bdbb rawtype: 21686148-6449-6e6f-744e-656564454649 label: (null) length: 524288 offset: 17408 type: bios-boot index: 1 end: 1057 start: 34 2. Name: da0p2 Mediasize: 16079216640 (15G) Sectorsize: 512 Stripesize: 0 Stripeoffset: 544768 Mode: r1w1e1 rawuuid: 2a3d8caa-a81d-11e4-9e59-002590d4bdbb rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 16079216640 offset: 544768 type: freebsd-zfs index: 2 end: 31405783 start: 1064 Consumers: 1. Name: da0 Mediasize: 16079781888 (15G) Sectorsize: 512 Mode: r1w1e2 Geom name: ada0 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada0p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 75725812-4116-11e4-a123-002590d4bdbb rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada0p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: 757db659-4116-11e4-a123-002590d4bdbb rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada0 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e3 Geom name: ada1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 75cbb813-4116-11e4-a123-002590d4bdbb rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada1p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: 75d77186-4116-11e4-a123-002590d4bdbb rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada1 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e3 Geom name: ada2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 762b42f1-4116-11e4-a123-002590d4bdbb rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada2p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: 7637a646-4116-11e4-a123-002590d4bdbb rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada2 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e3 Geom name: ada3 modified: false state: OK fwheads: 16 fwsectors: 63 last: 5860533134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 768edc23-4116-11e4-a123-002590d4bdbb rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada3p2 Mediasize: 2998445412352 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: 769a5b3b-4116-11e4-a123-002590d4bdbb rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2998445412352 offset: 2147549184 type: freebsd-zfs index: 2 end: 5860533127 start: 4194432 Consumers: 1. Name: ada3 Mediasize: 3000592982016 (2.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e3
