Can't assign IP to my TrueNAS machine
Samuel Tai
You should've said yes to the first question, to wipe out the current settings. Your NIC now has both the 10.212.126.6 AND the 192.168.0.14 addresses. You also didn't update your default route from 10.212.126.1 to 192.168.0.1.
zealios
I tried wiping the settings and update the default route to 192.168.0.1 (router ip)
Still nothing. :(
Samuel Tai
Then, how is your router configured?
zealios
Im not exactly sure what you mean, but hopefully this helps :)
Patrick M. Hausen
You have two interfaces according to the pictures. Sure you have the right one connected? Or the right one configured?
Samuel Tai
We're still trying to figure out where the 10.212.126.0/24 network is coming from.
Patrick M. Hausen
Is that what you meant?
No. Your Truenas has got two interfaces - bge0 and bge1. Try configuring bge0 instead of bge1 with your IP address.
Samuel Tai
What motherboard do you have? Are you plugged into the right port on the motherboard?
zealios
Not sure about the motherboard, but i have had it plugged in one of the 2 ports before, where it worked no problem.
Samuel Tai
No, you misunderstand. I suspect you're plugged into bge0, and not bge1. Run ifconfig bge1, and see if it has link, and is enabled.
zealios
I tried running both ifconfig bge1 and ifconfig bge0
Patrick M. Hausen
You need to clear the configuration on bge0. Or clear on bge1 and switch the cable to the other port. You cannot have the same IP address on two ports.
zealios
I tried switching the cable, and deleting the interface of bge1. Still no connection.
Patrick M. Hausen
ifconfig after you did that?
Samuel Tai
If you have the firmware download error on bge0, that's likely bad. Run everything on bge1.
