Askejm
- Feb 2, 2022
Yesterday I set up NextCloud on my NAS. It worked fine and I forwarded the port so my friends could store their stuff too. Everything worked fine until today it doesn't work anymore. Works fine from LAN, not from WAN.
Details that may be related:
TrueNAS-12.0-U8.1
CPU: i3-7100
RAM: 2x32 GB 2666 MHz CL19 (running at 2400 MHz CL17)
Motherboard: Asus Prime B250m-k
Storage: 3x4TB Ironwolf NAS
Ethernet port: TX401 (RJ45)
- My NAS has 2 LAN IPs. (idk why): 192.168.88.188 and 192.168.88.30. In TrueNas the stated admin portal was .188:8282, but it was using .30:8283. I set up port forwarding for both IPs, HTTP and HTTPS for both ports.
I don't see .30 in the settings though?
- My nat rules (Mikrotik router)
- It doesn't work on .30:8283 anymore, only .188:8283
- I tried disabling hardware offloading. Doesn't make a difference. When I did it yesterday it stopped working though
- I use a ddns which works properly (I can access TrueNas from wan)
- I tried connecting to:
- 192.168.88.188:8283 - Works, didn't work yesterday
- 192.168.88.30:8283 - Doesn't work, worked yesterday
- (ddns IP):8283 - Doesn't work, worked yesterday
- (my IP):8283 - Doesn't work (didn't test yesterday)
- All of the above but port 8282, never worked
- 192.168.88.188:8282 - I think it worked yesterday? That was my first install though, I started from scratch after
TrueNAS-12.0-U8.1
CPU: i3-7100
