Can't access data in dataset
Uluze2
I Had a boot drive fail replaced it got TN up and going it found my pools and data sets now when I try to access my smb shares the folders are there but no files show up. I can see that the data is still on the drives just opens to blank folder
Uluze2
root@truenas[~]# sudo zfs list -t all -r Sassy/Media
NAME USED AVAIL REFER MOUNTPOINT
Sassy/Media 2.69T 7.74T 2.69T /mnt/Sassy/Media
root@truenas[~]# sudo zfs get all Sassy/Media
NAME PROPERTY VALUE SOURCE
Sassy/Media type filesystem -
Sassy/Media creation Mon Oct 23 1:50 2023 -
Sassy/Media used 2.69T -
Sassy/Media available 7.74T -
Sassy/Media referenced 2.69T -
Sassy/Media compressratio 1.00x -
Sassy/Media mounted yes -
Sassy/Media quota none default
Sassy/Media reservation none default
Sassy/Media recordsize 128K default
Sassy/Media mountpoint /mnt/Sassy/Media default
Sassy/Media sharenfs off inherited from Sassy
Sassy/Media checksum on default
Sassy/Media compression off local
Sassy/Media atime off local
Sassy/Media devices on default
Sassy/Media exec on default
Sassy/Media setuid on default
Sassy/Media readonly off local
Sassy/Media zoned off default
Sassy/Media snapdir visible local
Sassy/Media aclmode passthrough local
Sassy/Media aclinherit passthrough local
Sassy/Media createtxg 19821 -
Sassy/Media canmount on default
Sassy/Media xattr sa local
Sassy/Media copies 1 local
Sassy/Media version 5 -
Sassy/Media utf8only off -
Sassy/Media normalization none -
Sassy/Media casesensitivity sensitive -
Sassy/Media vscan off default
Sassy/Media nbmand off default
Sassy/Media sharesmb off inherited from Sassy
Sassy/Media refquota none default
Sassy/Media refreservation none default
Sassy/Media guid 5308159499232904814 -
Sassy/Media primarycache all default
Sassy/Media secondarycache all default
Sassy/Media usedbysnapshots 0B -
Sassy/Media usedbydataset 2.69T -
Sassy/Media usedbychildren 0B -
Sassy/Media usedbyrefreservation 0B -
Sassy/Media logbias latency default
Sassy/Media objsetid 18295 -
Sassy/Media dedup off default
Sassy/Media mlslabel none default
Sassy/Media sync disabled local
Sassy/Media dnodesize legacy default
Sassy/Media refcompressratio 1.00x -
Sassy/Media written 2.69T -
Sassy/Media logicalused 2.69T -
Sassy/Media logicalreferenced 2.69T -
Sassy/Media volmode default default
Sassy/Media filesystem_limit none default
Sassy/Media snapshot_limit none default
Sassy/Media filesystem_count none default
Sassy/Media snapshot_count none default
Sassy/Media snapdev visible local
Sassy/Media acltype nfsv4 local
Sassy/Media context none default
Sassy/Media fscontext none default
Sassy/Media defcontext none default
Sassy/Media rootcontext none default
Sassy/Media relatime on default
Sassy/Media redundant_metadata all default
Sassy/Media overlay on default
Sassy/Media encryption off default
Sassy/Media keylocation none default
Sassy/Media keyformat none default
Sassy/Media pbkdf2iters 0 default
Sassy/Media special_small_blocks 0 local
Sassy/Media org.truenas:managedby 192.168.1.154 local
Sassy/Media org.freenas:description local
