Cannot use private docker hub container
sfatula
Did they remove Apps -> Manage Docker Images tab? Under that tab was a button to "Pull Image" which worked for private repos. I realize command line is gone but is there no GUI option now for private repos? I have a lot of password secured custom apps in a private repo.
sfatula
The doc shows no ability to pull from the private docker repo with a user and password?
kevinmatt
However, there seems to be no way to configure container-registry authentication like docker hub's private image, I can't pull my private docker image now.
DGTM
+1 would also like to see this available
I found this answer on FaceBook:
TrueNAS Scale:
Apps => Settings => Manage Container Images => Pull Image
I must say that the official TrueNAS documentation is very poor and missing a lot of stuff. And this truenas.com/community is not very helpful/useful either...
ABain
Bug Conductor
Politely, I'd like to disagree; this specific topic is covered in the TrueNAS documentation: https://www.truenas.com/docs/scale/23.10/scaleuireference/apps/#manage-container-images.
If you have feedback on items in the documentation, please use the feedback links on the documentation website; they are keen to get feedback on potential improvements.
As I reported earlier in the thread this was planned and implemented in the RC.1 release.
Oh, I had not seen that option to pull the image separately with credentials. This is great! Thank you, DGTM.
