SOLVED Cannot get Samba Share to work no matter what
Vexorify
I've recently just installed TrueNAS (13.0-U1.1) on an old PC for storage purposes. I imported my ZFS pool from a previous FreeBSD installation and there was no issue. I setup a new share within that pool, setup a user and made the user the owner of that new share. I can access the main directory of the TrueNAS just fine, but trying to access the share itself does not work at all. I tried searching multiple threads, but none of the solutions have worked so far. I've tried updating to 13.0-U2 as I saw there was a fix for SMB shares, it still didn't work. I've tried downgrading to 12.0-U8.1 via fresh install and still does not work.
(I've also tried via the IP and it still gives me this error)
Does anyone have a clue as to why this isn't working?
Davvo
Is your Windows username and password the same as the user you created?
If not, disabiling Windows Account should fix it.
Vexorify
I had the same user but different password before, but I did create that new account above which is different than my windows user.
Vexorify
Forgot to add, I did attempt disabling Microsoft Account and same error pops up
Davvo
Davvo
Can you post a screenshot of your Share Config? It's under Shares -> Windows Share (SMB)
Edit: is it the second picture? I am not used to basic options view.
LarsR
A Screenshot of the Datasets ACL's would also be good. If you've never edited the ACL's of the Dataset it's expected to not allow acces to it.
Vexorify
Here is my output when I run the testparm command
Welcome to TrueNAS
Warning: settings changed through the CLI are not written to
the configuration database and will be reset on reboot.
root@truenas[~]# testparm -s -v
Load smb config files from /usr/local/etc/smb4.conf
Loaded services file OK.
Weak crypto is allowed
Server role: ROLE_STANDALONE
# Global parameters
[global]
        abort shutdown script =
        add group script =
        additional dns hostnames =
        add machine script =
        addport command =
        addprinter command =
        add share command =
        add user script =
        add user to group script =
        ads dns update = Yes
        afs token lifetime = 604800
        afs username map =
        aio max threads = 2
        algorithmic rid base = 1000
        allow dataset creation = Yes
        allow dcerpc auth level connect = No
        allow dns updates = secure only
        allow insecure wide links = No
        allow nt4 crypto = No
        allow trusted domains = Yes
        allow unsafe cluster upgrade = No
        apply group policies = No
        async smb echo handler = No
        auth event notification = No
        auto services =
        binddns dir = /var/run/samba4/bind-dns
        bind interfaces only = Yes
        browse list = Yes
        cache directory = /var/run/samba4
        change notify = Yes
        change share command =
        check password script =
        cldap port = 389
        client ipc max protocol = default
        client ipc min protocol = default
        client ipc signing = default
        client lanman auth = No
        client ldap sasl wrapping = sign
        client max protocol = default
        client min protocol = SMB2_02
        client NTLMv2 auth = Yes
        client plaintext auth = No
        client schannel = Yes
        client signing = default
        client use spnego principal = No
        client use spnego = Yes
        cluster addresses =
        clustering = No
        config backend = file
        config file =
        create krb5 conf = Yes
        ctdbd socket =
        ctdb locktime warn threshold = 0
        ctdb timeout = 0
        cups connection timeout = 30
        cups encrypt = No
        cups server =
        dcerpc endpoint servers = epmapper, wkssvc, rpcecho, samr, netlogon, lsarpc, drsuapi, dssetup, unixinfo, browser, eventlog6, backupkey, dnsserver
        deadtime = 10080
        debug class = No
        debug encryption = No
        debug hires timestamp = Yes
        debug pid = No
        debug prefix timestamp = No
        debug uid = No
        dedicated keytab file =
        default service =
        defer sharing violations = Yes
        delete group script =
        deleteprinter command =
        delete share command =
        delete user from group script =
        delete user script =
        dgram port = 138
        disable netbios = No
        disable spoolss = Yes
        dns forwarder =
        dns proxy = No
        dns update command = /usr/local/sbin/samba_dnsupdate
        dns zone scavenging = No
        domain logons = No
        domain master = Auto
        dos charset = CP850
        dsdb event notification = No
        dsdb group change notification = No
        dsdb password event notification = No
        enable asu support = No
        enable core files = Yes
        enable privileges = Yes
        enable web service discovery = Yes
        encrypt passwords = Yes
        enhanced browsing = Yes
        enumports command =
        eventlog list =
        get quota command =
        getwd cache = Yes
        gpo update command = /usr/local/sbin/samba-gpupdate
        guest account = nobody
        homedir map = auto.home
        host msdfs = Yes
        hostname lookups = No
        idmap backend = tdb
        idmap cache time = 604800
        idmap gid =
        idmap negative cache time = 120
        idmap uid =
        include system krb5 conf = Yes
        init logon delay = 100
        init logon delayed hosts =
        interfaces =
        iprint server =
        keepalive = 300
        kerberos encryption types = all
        kerberos method = default
        kernel change notify = No
        kpasswd port = 464
        krb5 port = 88
        lanman auth = No
        large readwrite = Yes
        ldap admin dn =
        ldap connection timeout = 2
        ldap debug level = 0
        ldap debug threshold = 10
        ldap delete dn = No
        ldap deref = auto
        ldap follow referral = Auto
        ldap group suffix =
        ldap idmap suffix =
        ldap machine suffix =
        ldap max anonymous request size = 256000
        ldap max authenticated request size = 16777216
        ldap max search request size = 256000
        ldap page size = 1000
        ldap passwd sync = no
        ldap replication sleep = 1000
        ldap server require strong auth = Yes
        ldap ssl = start tls
        ldap suffix =
        ldap timeout = 15
        ldap user suffix =
        lm announce = Auto
        lm interval = 60
        load printers = No
        local master = Yes
        lock directory = /var/run/samba4
        lock spin time = 200
        log file =
        logging = file
        log level = 1
        log nt token command =
        logon drive =
        logon home = \\%N\%U
        logon path = \\%N\%U\profile
        logon script =
        log writeable files on exit = No
        lpq cache time = 30
        lsa over netlogon = No
        machine password timeout = 604800
        mangle prefix = 1
        mangling method = hash2
        map to guest = Never
        max disk size = 0
        max log size = 5120
        max mux = 50
        max open files = 466605
        max smbd processes = 0
        max stat cache size = 512
        max ttl = 259200
        max wins ttl = 518400
        max xmit = 16644
        mdns name = netbios
        message command =
        min domain uid = 1000
        min receivefile size = 0
        min wins ttl = 21600
        mit kdc command =
        multicast dns register = Yes
        name cache timeout = 660
        name resolve order = lmhosts wins host bcast
        nbt client socket address = 0.0.0.0
        nbt port = 137
        ncalrpc dir = /var/run/samba4/ncalrpc
        netbios aliases =
        netbios name = TRUENAS
        netbios scope =
        neutralize nt4 emulation = No
        NIS homedir = No
        nmbd bind explicit broadcast = Yes
        ntlm auth = ntlmv2-only
        nt pipe support = Yes
        ntp signd socket directory = /var/run/samba4/ntp_signd
        nt status support = Yes
        null passwords = No
        obey pam restrictions = No
        old password allowed period = 60
        oplock break wait time = 0
        os2 driver map =
        os level = 20
        pam password change = No
        panic action =
        passdb backend = tdbsam
        passdb expand explicit = No
        passwd chat = *new*password* %n\n *new*password* %n\n *changed*
        passwd chat debug = No
        passwd chat timeout = 2
        passwd program =
        password hash gpg key ids =
        password hash userPassword schemes =
        password server = *
        perfcount module =
        pid directory = /var/run/samba4
        preferred master = Auto
        prefork backoff increment = 10
        prefork children = 4
        prefork maximum backoff = 120
        preload modules =
        printcap cache time = 750
        printcap name =
        private dir = /var/db/system/samba4/private
        raw NTLMv2 auth = No
        read raw = Yes
        realm =
        registry shares = Yes
        reject md5 clients = No
        reject md5 servers = No
        remote announce =
        remote browse sync =
        rename user script =
        require strong key = Yes
        reset on zero vc = No
        restrict anonymous = 2
        root directory =
        rpc big endian = No
        rpc server dynamic port range = 49152-65535
        rpc server port = 0
        samba kcc command = /usr/local/sbin/samba_kcc
        security = AUTO
        server max protocol = SMB3
        server min protocol = SMB2_02
        server multi channel support = No
        server role = standalone server
        server schannel = Yes
        server services = s3fs, rpc, nbt, wrepl, ldap, cldap, kdc, drepl, winbindd, ntp_signd, kcc, dnsupdate, dns
        server signing = default
        server string = Samba 4.13.17
        set primary group script =
        set quota command =
        share backend = classic
        show add printer wizard = Yes
        shutdown script =
        smb2 disable lock sequence checking = No
        smb2 disable oplock break retry = No
        smb2 leases = Yes
        smb2 max credits = 8192
        smb2 max read = 8388608
        smb2 max trans = 8388608
        smb2 max write = 8388608
        smbd profiling level = off
        smb passwd file = /var/db/system/samba4/private/smbpasswd
        smb ports = 445 139
        socket options = TCP_NODELAY
        spn update command = /usr/local/sbin/samba_spnupdate
        stat cache = Yes
        state directory = /var/db/system/samba4
        svcctl list =
        syslog = 1
        syslog only = No
        template homedir = /home/%D/%U
        template shell = /bin/false
        time server = No
        timestamp logs = Yes
        tls cafile = tls/ca.pem
        tls certfile = tls/cert.pem
        tls crlfile =
        tls dh params file =
        tls enabled = Yes
        tls keyfile = tls/key.pem
        tls priority = NORMAL:-VERS-SSL3.0
        tls verify peer = as_strict_as_possible
        truenas passive controller = No
        unicode = Yes
        unix charset = UTF-8
        unix extensions = No
        unix password sync = No
        use mmap = Yes
        username level = 0
        username map =
        username map cache time = 0
        username map script =
        usershare allow guests = No
        usershare max shares = 0
        usershare owner only = Yes
        usershare path = /var/db/system/samba4/usershares
        usershare prefix allow list =
        usershare prefix deny list =
        usershare template share =
        utmp = No
        utmp directory =
        winbind cache time = 300
        winbindd socket directory = /var/run/samba4/winbindd
        winbind enum groups = No
        winbind enum users = No
        winbind expand groups = 0
        winbind max clients = 200
        winbind max domain connections = 1
        winbind nested groups = Yes
        winbind netbios alias spn = Yes
        winbind normalize names = No
        winbind nss info = template
        winbind offline logon = No
        winbind reconnect delay = 30
        winbind refresh tickets = No
        winbind request timeout = 60
        winbind rpc only = No
        winbind scan trusted domains = Yes
        winbind sealed pipes = Yes
        winbind separator = \
        winbind status fifo = No
        winbind use default domain = No
        winbind use krb5 enterprise principals = No
        wins hook =
        wins proxy = No
        wins server =
        wins support = No
        workgroup = WORKGROUP
        write raw = Yes
        wtmp directory =
        zeroconf name =
        idmap config * : backend = tdb
        access based share enum = No
        acl allow execute always = No
        acl check permissions = Yes
        acl group control = No
        acl map full control = Yes
        administrative share = No
        admin users =
        afs share = No
        aio read size = 1
        aio write behind =
        aio write size = 1
        allocation roundup size = 0
        available = Yes
        blocking locks = Yes
        block size = 1024
        browseable = Yes
        case sensitive = Auto
        check parent directory delete on close = No
        comment =
        copy =
        create mask = 0744
        csc policy = manual
        cups options =
        default case = lower
        default devmode = Yes
        delete readonly = No
        delete veto files = No
        dfree cache time = 0
        dfree command =
        directory mask = 0755
        directory name cache size = 0
        dmapi support = No
        dont descend =
        dos filemode = Yes
        dos filetime resolution = No
        dos filetimes = Yes
        durable handles = Yes
        ea support = Yes
        fake directory create times = No
        fake oplocks = No
        follow symlinks = Yes
        force create mode = 0000
        force directory mode = 0000
        force group =
        force printername = No
        force unknown acl user = No
        force user =
        fstype = NTFS
        guest ok = No
        guest only = No
        hide dot files = Yes
        hide files =
        hide new files timeout = 0
        hide special files = No
        hide unreadable = No
        hide unwriteable files = No
        hosts allow =
        hosts deny =
        include =
        inherit acls = No
        inherit owner = no
        inherit permissions = No
        invalid users =
        kernel dosmodes = No
        kernel oplocks = No
        kernel share modes = Yes
        level2 oplocks = Yes
        locking = Yes
        lppause command =
        lpq command = lpq -P'%p'
        lpresume command =
        lprm command = lprm -P'%p' %j
        magic output =
        magic script =
        mangled names = illegal
        mangling char = ~
        map acl inherit = No
        map archive = Yes
        map hidden = No
        map readonly = no
        map system = No
        max connections = 0
        max print jobs = 1000
        max reported print jobs = 0
        min print space = 0
        msdfs proxy =
        msdfs root = No
        msdfs shuffle referrals = No
        nt acl support = Yes
        ntvfs handler = unixuid, default
        oplocks = Yes
        path =
        posix locking = Yes
        postexec =
        preexec =
        preexec close = No
        preserve case = Yes
        printable = No
        print command = lpr -r -P'%p' %s
        printer name =
        printing = bsd
        printjob username = %U
        print notify backchannel = No
        queuepause command =
        queueresume command =
        read list =
        read only = Yes
        root postexec =
        root preexec =
        root preexec close = No
        short preserve case = Yes
        smbd async dosmode = No
        smbd getinfo ask sharemode = Yes
        smbd max async dosmode = 0
        smbd max xattr size = 2097152
        smbd search ask sharemode = Yes
        smb encrypt = default
        spotlight = No
        spotlight backend = noindex
        store dos attributes = Yes
        strict allocate = No
        strict locking = Auto
        strict rename = No
        strict sync = Yes
        sync always = No
        use client driver = No
        use sendfile = No
        valid users =
        veto files =
        veto oplock files =
        vfs objects =
        volume =
        wide links = No
        write list =
[vex]
        ea support = No
        kernel share modes = No
        path = /mnt/storage1/vex
        posix  locking = No
        read only = No
        vfs objects = streams_xattr shadow_copy_zfs ixnas aio_fbsd
        nfs4:chown = true
        wide links = No
anodos
Sambassador
okay. The issue is your permissions on /mnt/storage1. It looks like you may have manually run chmod 770 on that path, which breaks access to everything on your pool.
chmod 755 /mnt/storage1 should fix your SMB shares.
Vexorify
This fixed it, thank you very much!
