Cannot Create Pool
StarsAndBars
Hello! I am trying to get a new instance of Scale up and running (my first) and I can't seem to get my storage pool established. When I select the disks to add to a RAID-Z array and continue, the create pool dialogue box never goes away (in other videos I have watched this process is almost instantaneous) and then I notice an alert about my disks being formatted with Data Integrity Feature (DIF) and I am not familiar with this or how to remove it. Any advice would be greatly appreciated. Thanks in advance!
Samuel Tai
In particular, click the blue buttons corresponding to T10-PI and Branded.
rexl
Is anyone can help me with this issue?
The following message showed when I tried to create disk pool.
"[EFAULT] Disk: 'sdad' is incorrectly formatted with Data Integrity Feature (DIF)"
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 428, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 463, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1246, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1378, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 779, in do_create
await self.middleware.call('pool.format_disks', job, disks)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1395, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1344, in _call
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 33, in format_disks
await asyncio_map(format_disk, disks.items(), limit=16)
File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map
return await asyncio.gather(*futures)
File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio_.py", line 13, in func
return await real_func(arg)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 25, in format_disk
await self.middleware.call('disk.format', disk, config.get('min_size'), swap_size, False)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1355, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1258, in run_in_executor
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk_/format.py", line 56, in format
swapsize, alignment = self.validate_disk(disk, min_size, swapgb)
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk_/format.py", line 20, in validate_disk
raise CallError(f'Disk: {disk!r} is incorrectly formatted with Data Integrity Feature (DIF).')
middlewared.service_exception.CallError: [EFAULT] Disk: 'sdy' is incorrectly formatted with Data Integrity Feature (DIF).
Have you looked here? (as linked above in this thread):
